Honda Hornet, New Battery already dead?
StottyB
PostPosted: 09:14 - 23 Jun 2008    Post subject: Honda Hornet, New Battery already dead? Reply with quote
Hi guys,
I fitted a new battery to the bike because my old battery died (literally completely dead, wouldn't even bump stasrt) and it worked fine for about two days. Tried starting it this morning and it's as good as dead again already!
When i started it after fitting the new battery, when revving the headlight did not get any brighter, does this suggest its the reg/rec?
1999 Honda Hornet
Could it be anything else?
Thanks!!
2005 Gilera Stalker 50DT ---> 2003 NSR125R ---> **1999 Honda Hornet 600**
PostPosted: 09:45 - 23 Jun 2008    Post subject: Reply with quote
Suggests charging system. And the most likely charging system fault is the regulator / rectifier. Could also be blown fuse, broken wire or a faulty winding on the stator.
StottyB
PostPosted: 09:56 - 23 Jun 2008    Post subject: Reply with quote
Thank you very much for the reply!
Can i recharge the new battery so i don't have to bother buying another one?
Are there any tests of anything i can do to determine the problem? i don't have a multimeter and can't really afford to change the reg/rec only to find thats not the problem.
PostPosted: 10:08 - 23 Jun 2008    Post subject: Reply with quote
Yes you can recharge it. Don't use a car charger (you can get away with it for a short time, but leaving it to charge up fully on one is likely to damage it).
Afraid you really need a multimeter to check things out. Check for continuity over the windings and check for a circuit from the regulator / rectifier to the battery. You can also check the AC voltage over the wires going into the regulator / rectifier.
The last post was made 17 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.29 - MySQL Queries: 15 - Page Size: 41.06 Kb
