indicaters
simsimma
PostPosted: 15:35 - 22 Jun 2008    Post subject: indicaters Reply with quote
i bourght four l,e,d indicaters for my nsr put them on and thay dont flash so started taking them off and thay flash with two old ones and two new one i read the packet thay came in and it said you may need a flash unit so bourght that and it blew the fuse can any one help pls
SM.Morgan
PostPosted: 01:25 - 23 Jun 2008    Post subject: Reply with quote
You might need a bigger fuse because of the flasher unit, try reading the packaging etc to see if it gives you any clues.
Harley XR1200
Damon
PostPosted: 06:43 - 23 Jun 2008    Post subject: Reply with quote
how old are you?
simsimma
PostPosted: 05:54 - 24 Jun 2008    Post subject: Reply with quote
Carnt get them to work i give up & i am 26 why you ask
iooi
PostPosted: 08:22 - 24 Jun 2008    Post subject: Reply with quote
I think he's asking as you post was so hard to read and understand.
A forum is not a mobile phone with a word limit Thumbs Up
Phoenix
Twisted Firestarter
PostPosted: 19:49 - 24 Jun 2008    Post subject: Reply with quote
My money is on you fluffing the fitting of them, you've got a short circuit somewhere if your blowing fuses, check your wiring is correct and none of it is earthing out. If you fit the flasher relay you'll need all indicators to be LED not half and half, the other solution is to fit load resistors in parallel to each indicator to create the same resistance as a bulb.
The last post was made 18 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 47 Kb
