petrol cap not releasing - now need replacement keys
cnb1000
PostPosted: 19:19 - 24 Jun 2008    Post subject: petrol cap not releasing - now need replacement keys Reply with quote
I have been running the tank on empty for a few days with the light on and finally went to fill up on the way home from work only to find that I could not get the cap to unlock. I've a Kawasaki ER6N, 500miles, so have only filled up a couple of times.
I got back home and starting trying to unlock it then managed to twist the key a little too much so it won't go in the ignition.
I sprayed a little DD40 onto the cap and that seemed to work, only now I have one knackered key.
Where should I go to get a new key without going back to the dealer/how much should it cost (I have the serial number)
cheers
chris
Yamaha YBR125 - Kawasaki ER6N
Itchy
PostPosted: 19:22 - 24 Jun 2008    Post subject: Reply with quote
if he charges you more than £35 get a race petrol tank filler cap, froggy had one where the entire filler cap comes out when you lock it, but if it has broken in <500 miles surely this should be covered by warranty?
iooi
PostPosted: 19:35 - 24 Jun 2008    Post subject: Reply with quote
Any key cutting place will be able to cut a new one from the spare you should have.
Often you may find you have to push the cap down a bit before twisting the key. But if this is a brand new bike i would be going back to the dealer and asking them to sort the problem.
cnb1000
PostPosted: 19:46 - 24 Jun 2008    Post subject: Reply with quote
cheers. will take your advice and go to the general key cutter, who needs a bike logo on a key anyway.
Sparks!
Sir Tart-a-lot
PostPosted: 19:49 - 24 Jun 2008    Post subject: Reply with quote
Once you safely have a new key cut... carefully heat up the old one and see if it will bend back in a vice (put it in vice and close vice up, not clamp one bit then try to bend it.. if that makes sense?) keys are kinda brittle, BUT I've bent back 2 keys easy enough and still going strong today so it is possible and worth trying...
Flip
PostPosted: 21:30 - 24 Jun 2008    Post subject: Reply with quote
When it happened to me I fixed it with a hammer. I was on a petrol forecourt and had no choice. Laughing
ZRX61
Victor Meldrew
PostPosted: 23:14 - 24 Jun 2008    Post subject: Reply with quote
Kaw keys are made from butter, you can straigten them with your fingers.. Wink
& all kaw's use the same lock design on the tank, just press down a bit on the cap as you turn the key... & also use the key when you close it.. at least until the lock loosens up a bit, usually around 90,000 miles IME
PostPosted: 00:22 - 25 Jun 2008    Post subject: Reply with quote
Get a pencil and scrible all over the key the graphite lubs the lock and mades it easier to turn, a bit of 3in1 would go a miss either.
The keys bend back really easy just put it back in the lock and turn the other way.
Flip
PostPosted: 18:14 - 25 Jun 2008    Post subject: Reply with quote
"...turn the other way" And see if it snaps in the lock. Laughing
The last post was made 17 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 59.97 Kb
