Green Wrie?????????????????
Mini_Stalk
PostPosted: 20:44 - 24 Jun 2008    Post subject: Green Wrie????????????????? Reply with quote
On my cb 125 tdc there is a green wire under the seat but i cant find were it goes.
SR 125 Rat
finpos
PostPosted: 20:51 - 24 Jun 2008    Post subject: Reply with quote
Does the dash repeater for your indicators work?
f.
Ant132
PostPosted: 20:52 - 24 Jun 2008    Post subject: Reply with quote
My bike is similar.. I asked about it and found that some models of my bike had rectifiers but all models used the same loom, but the wire was useless.
Could it be to the rectifier?
Take a look at this wiring diagram..
Ant Thumbs Up
1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200
Mini_Stalk
PostPosted: 20:55 - 24 Jun 2008    Post subject: Reply with quote
f.
The indercaters just come on and don't flash whilst the flasher relay just buzzes.
SR 125 Rat
Mini_Stalk
PostPosted: 20:56 - 24 Jun 2008    Post subject: Reply with quote
Ant Thumbs Up
I dont think it is that. It looks rather new.
SR 125 Rat
Sparks!
Sir Tart-a-lot
PostPosted: 20:58 - 24 Jun 2008    Post subject: Reply with quote
Try touching that green wire to the frame and see if the indicators work after that...
finpos
PostPosted: 21:00 - 24 Jun 2008    Post subject: Reply with quote
First, check your battery is a) fully charged and b) not knackered
Next, that looks like a replacement indicator flasher, it may be the wrong type (two wire as opposed to 3 wire type) which may cause a problem, depending on what bulbs are fitted.
f.
Mini_Stalk
PostPosted: 21:02 - 24 Jun 2008    Post subject: Reply with quote
f.
If the bulbs are blown in the indercators could that make a difference.
SR 125 Rat
Sparks!
Sir Tart-a-lot
PostPosted: 21:06 - 24 Jun 2008    Post subject: Reply with quote
f.
You said they come on but don't flash so there bulbs are fine.... Have you just replaced anything to do with the indicators on the bike or have they not worked since you got the bike? i thought they once worked but now don't and you found a loose cable.... bit confused now.
finpos
PostPosted: 21:08 - 24 Jun 2008    Post subject: Reply with quote
No, if the bulbs are the wrong rating with respect to the flasher, the flasher won't work.
f.
Mini_Stalk
PostPosted: 21:14 - 24 Jun 2008    Post subject: Reply with quote
You said they come on but don't flash so there bulbs are fine.... Have you just replaced anything to do with the indicators on the bike or have they not worked since you got the bike? i thought they once worked but now don't and you found a loose cable.... bit confused now.[/quote]
It has been like that since i got the bike. what would be the the best thing/s to do.
SR 125 Rat
finpos
PostPosted: 21:34 - 24 Jun 2008    Post subject: Reply with quote
1. Make sure the battery is charged and not knackered. You don't have to tools to do this, so use a battery out of something else that you know works absolutely fine. e.g. use jump leads off a car battery.
2. If it still does not work, then you need to make sure the load presented by the bulbs to the flasher unit is appropriate to that flasher unit. It looks in your case that somebody has replaced a 3 wire unit with a 2 wire unit, and, one assumes, did not change the bulbs to match. To be sure, you will have to find out the rating of the unit (if you are lucky, it will be printed on the case), the rating of each of the 4 indicator bulbs plus the repeater in the dash, and you will need a link to a wiring diagram that actually works.
Plus you could answer the original question.
f.
Phoenix
Twisted Firestarter
PostPosted: 22:09 - 24 Jun 2008    Post subject: Reply with quote
f.
This is the correct answer IMO. That was the indicator relay and it's been replaced with the wrong one by the looks with too few spade terminals, therefore leaving the green wire with nowhere to go. Get a replacement and it'll fix the indicators and give your green wire a home.
Lone-Wolf
PostPosted: 22:56 - 24 Jun 2008    Post subject: Reply with quote
Wotcha.
Looks like the earth wire from the flasher unit to me.
If you notice, the other green wire in the picture is bolted to a frame earth lug.
Cheers.
L.W. - www.moonshiners.org.uk
Odie
PostPosted: 01:53 - 25 Jun 2008    Post subject: Reply with quote
Green is earth on honda's Thumbs Up
PostPosted: 13:25 - 25 Jun 2008    Post subject: Reply with quote
Agreed, if it's and original wire and it's green, it's an earth on a honda. It should be connected to a componant at one end and either the frame, another green wire or the battery negative at the other end.
Unless it's a kind of light snot green, in which case it's the neutral light.
The last post was made 18 years, 117 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.34 - MySQL Queries: 15 - Page Size: 92.06 Kb
