Why no Ally exhausts?
Aikman666
PostPosted: 23:49 - 24 Jun 2008    Post subject: Why no Ally exhausts? Reply with quote
Apon having a wee chat with the old man tonight who is both a seasoned rider and engineer I was talking about riveting my end can back together and was a bit apprehensive about using Aluminium alloy rivets incase they just melt away; to which he replied they're good up to around 120 degrees C.
So in that case, why dont bike manufacturers make exhaust systems out of it? Surely if the head can take the heat (as they are cast ally) then the pipes could too? With the added advantage of corrosion resistance, being cheaper and quite a portion lighter too.
So why havent I ever heard of it being done?
Neither of us could think of the answer.
Will work for petrol
My Design Blog
tatters
Exxon Valdez
PostPosted: 23:52 - 24 Jun 2008    Post subject: Re: Why no Ally exhausts? Reply with quote
Aluminum is a lot more expensive than mild steel
Aikman666
PostPosted: 23:55 - 24 Jun 2008    Post subject: Reply with quote
Alot of the systems i see these days are Stainless steel systems. But still it may be more expensive, yet I've never seen it on the best of race bikes etc?
My Design Blog
bagger
PostPosted: 01:07 - 25 Jun 2008    Post subject: Reply with quote
im pretty sure down pipes get hotter than 120C ive seen pics of some glowing red
Kwaks
I'm not a fast rider
PostPosted: 04:53 - 25 Jun 2008    Post subject: Reply with quote
No benefits to Ally, only downsides.
Yes it is about half the weight of steel, but only about 1/3 as strong, so would end up weighing more to match the strength.
More corrosive than steel, so no advantages there.
Down pipes get too hot for ally, and the whole system is substancially weakened by the heat through the system not to mention the stresses caused through the expansion.
The 3 most viable options remain S/S, Carbon & Titanium.
www.cliqueycuntsmcc.co.uk
Ariel Badger
PostPosted: 06:25 - 25 Jun 2008    Post subject: Reply with quote
The Badger uses one of these..
https://cgi.ebay.co.uk/Alloy-Trials-Silencer-Pre-65-AJS-BSA-Ariel-Enfield-AMC_W0QQitemZ270249208421QQcmdZViewItem?hash=item270249208421&_trkparms=72%3A12%7C39%3A1%7C65%3A12&_trksid=p3286.c0.m14
and some Broughs used ali downpipes with cooling fins.
c_dug
PostPosted: 10:16 - 25 Jun 2008    Post subject: Reply with quote
My DEP end cans are ally, can vouch for them being weak as ive already had to have one of them welded once so i wouldnt personally go for the whole system even if it were available.
c_dug
PostPosted: 11:28 - 25 Jun 2008    Post subject: Reply with quote
And aluminium doesn't melt at 120c Wink It's obviously a typo. We're not talking about solder here Laughing
Aikman666
PostPosted: 12:01 - 25 Jun 2008    Post subject: Reply with quote
The rivets we were talking about are an aluminium alloy as I understand it, probably to be plyable enough to be riveted in the first place. Aluminiums melting point is around 660 degrees C.
Kwacker is quite right, while it is one third the weight of mild steel it is also one third the strength, but how strong does an exhaust system really have to be? Surely there cant be alot of strain on it.
But it does however give much better corrosion resistance than its mild steel and certain grades of stainless steel counterparts.
Hmm
My Design Blog
PostPosted: 12:05 - 25 Jun 2008    Post subject: Reply with quote
Aluminium alloy melting points are around 600 centigrade. Quite a lot lower than the easily attained exhaust gas temperature.
Ichy
PostPosted: 12:15 - 25 Jun 2008    Post subject: Reply with quote
Aluminium melts at about 660c but goes soft way before then. Pure guess that exhaust gases are about 200-300c at the header.
Corrosion is going to be another problem, exhaust gases mixed with water form hydrochloric, Sulfuric, nitric, carbonic and other bad acid stuff.
Then you have stress, aluminium has a short fatigue life made worse by the heat expansion.
Someone is developing a titanium aluminium alloy to use with exhausts making them about 50% lighter but I don't think that is recommended for header pipes.
If I was to make a lightweight exhaust I'd go for thin gauge stainless, F1 teams used to use Inconel, no idea what they use now.
Ichy
PostPosted: 12:17 - 25 Jun 2008    Post subject: Reply with quote
Sorry, didn't see your post, any idea what sort of temperature exhaust gases are at the manifold? I never realised they went that high.
PostPosted: 12:38 - 25 Jun 2008    Post subject: Reply with quote
From a brief look around, exhaust gas temperature gauges are used on some microlight. The expected temperature was ~1250 centigrade (which is actually above the melting point of cast iron).
This is the gas temperatue at a point. Presume the temperature of the gas where it meets the exhaust walls is lower, and also that the exhaust gas is only at that temperature at a certain point in the combustion process.
Mr Nice Guy
PostPosted: 13:17 - 25 Jun 2008    Post subject: Reply with quote
Something to think about, considering that little bundle of joy (heat) is less than 10 inches below your balls!! Laughing
Suzuki GSX-R750K4 ~ Mivv GP
sidey
PostPosted: 14:04 - 25 Jun 2008    Post subject: Reply with quote
and how far away if yer female ? Razz
Old man
PostPosted: 14:46 - 25 Jun 2008    Post subject: Reply with quote
The header pipes will be at around 600-700 degs C, Aluminium may melt at around 660 but what were talking about is alloy, which has a considerablely lower melt point. For an ali exhaust sytem to be viable the headers would have to be much thicker to disipate the heat and be stong enough. If it was viable you would have seen them on GP bikes by now.
map
Mr Calendar
PostPosted: 15:12 - 25 Jun 2008    Post subject: Reply with quote
Ichy wrote:
...Corrosion is going to be another problem, exhaust gases mixed with water form hydrochloric, Sulfuric, nitric, carbonic and other bad acid stuff....
Remembering my metal bashing days I've always been under the impression that aluminum is quite stable as it instantly forms a coating of aluminum oxide on the surface. This is normally quite difficult to get through, although an acid of sufficient concentration can certainly etch it.
Agree on the temperatures though, waiting to be corrected on the corrosion.
Ichy
PostPosted: 15:30 - 25 Jun 2008    Post subject: Reply with quote
Your right up to a point, except the oxide is unstable when the PH is less than 4 or greater than 9. Effects are exaggerated at higher temperatures.
Mr Nice Guy
PostPosted: 15:34 - 25 Jun 2008    Post subject: Reply with quote
If you want to sit on my bike, I'm willing to measure Razz
*provided you are female, of course* Laughing
Ichy
PostPosted: 15:45 - 25 Jun 2008    Post subject: Reply with quote
What alloy? Aluminium is used for all sorts including applications with a gas temperature of 3500k.
Nobody has said they were viable, certainly not economically, I think most have agreed the opposite.
PostPosted: 17:04 - 25 Jun 2008    Post subject: Reply with quote
I've had ally end-cans before, no problem apart from how easy they are to damage.
Typical exhaust gas temps are 900-1100 deg C in the headers. The temps drop significantly as the exhaust travels down the pipes.
The reason ally heads don't melt under normal use is because heat is dissipated away too fast. It's what a cylinder head is designed to do after-all. It is possible to partially melt the head on a bike but not easy as the piston usually pops first.
PostPosted: 17:15 - 25 Jun 2008    Post subject: Reply with quote
What about the OP? He asked a question, Old man answered it aswell as everyone else. He is just joining in with the discussion.
The last post was made 18 years, 131 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 124.08 Kb
