Peugeot Speedfight
SpeedfightBoi
PostPosted: 10:12 - 25 Jun 2008    Post subject: Peugeot Speedfight Reply with quote
Hi I have been lurking around on this forum for quite a while and have just decided to register to such a wonderful forum (Y)
I have just purchased an 07 Peugeot Speedfight 2 50cc.
The bloke says it is de-restricted, has a race pipe(leo vince TT) which is also de-restricted and has 6.7 gram Leo Vince race rollers- But only goes 42mph on the flat.....Surely it should go faster than that? I have pm'ed him and he says he weighs 12 stone. What are your views on it guys
Thanks in advance Thumbs Up
PostPosted: 10:35 - 25 Jun 2008    Post subject: Reply with quote
I would say it should hit 45mph.
Sounds to me like the exhaust is still restricted. Mine will do 42ish and I've still got a restricted exhaust.
You'll have to take it off and see if there is a washer welded in the exhaust where it meets the head.
Piece of piss to get the exhaust of Speedfights though. 3 nuts in the seat bucket, 2 nuts where the exhaust attaches to the engine and 2 allen bolts where the exahust bracket attaches to the engine.
The bracket may be different though, I'm going off what a standard speedfight exhaust has.
matt46cars
PostPosted: 18:55 - 25 Jun 2008    Post subject: Reply with quote
there is also a washer in the variator casingthats a link on how to remove it and also about desrestricting 50cc bikes
hope it helps
https://www.flexistentialist.org/blog/archives/2003/10/28/de-restricting-an-aprilia-scooter-or-most-any-modern-scooter
PostPosted: 19:22 - 25 Jun 2008    Post subject: Reply with quote
hope it helps
It's very unlikely to be that. It would never reach 42mph with the variator restriction in and the exhaust restriction out. Max you would reach would be about 33-35mph.
SpeedfightBoi
PostPosted: 20:49 - 25 Jun 2008    Post subject: Reply with quote
Thanks for the replies guys...When i collected the bike, the small tube thing from the exhaust was in a bag.. with drill scuff marks on it which he removed from the exhaust and also the 10p sized washer was in a seperate bag along with the old rollers. So i asked him why it only does that speed he had no idea :S
PostPosted: 21:36 - 25 Jun 2008    Post subject: Reply with quote
Could be to do with the roller weights but I'm not much of an expert when it comes to the weights.
matt46cars
PostPosted: 08:31 - 26 Jun 2008    Post subject: Reply with quote
lighter weight rollers are for acceleration and heavier rollers are for top end
i have an aerox with deristricted exhaust,deristricted variator and 2x 3gram rollers and 1x 8 gram and bike has loads of both acceleration and top end and flys round the clock and does about 60+
PostPosted: 09:14 - 26 Jun 2008    Post subject: Reply with quote
That's not true. I don't know which weight would be best but I know that rollers will never increase top end. You could get lighter rollers but because it's keeping it in the powerband increase top speed and acceleration.
The different weights of rollers are so that it can keep the engine in the powerband. When you change the exhaust the location of the powerband changes so the rollers have to be changed too to keep it in that powerband.
Your Aerox doesn't do 60+, it's impossible unless you have a 70cc kit and a gear up kit.
zetecy
PostPosted: 21:18 - 26 Jun 2008    Post subject: Reply with quote
the rollers could be worn. i had a 05 speedfight 2 and its top speed was 50mph and its acceleration was very good (for a scoot) i was changing rollers every 2500 miles, but i must state buy genuin peugeot rollers! i tried others ones and i had some even melt in the variator. peugeot rollers are 8grams and they are the best settup, do not even change the springs in the clutch.
heres a vid of mine, (sold now) https://www.youtube.com/watch?v=4bfC5OioucQ
oh and to add, it had leovince TT, 0.80 main jet and a K&N style. standard are 0.50 main jet
binge
Emo Kiddy
PostPosted: 21:23 - 26 Jun 2008    Post subject: Reply with quote
You do realise that running mixed rollers like that will bend your crank.
You can run different rollers providing they are even. i.e.
5g, 4g, 5g, 4g, 5g, 4g.
Rollers will not affect the top speed, they will just affect how quickly the scooter gets there.
Please stop giving advice on something you clearly know fuck all about.
Ben
Spit-Fire
PostPosted: 08:09 - 27 Jun 2008    Post subject: Reply with quote
i think there slow bikes in general (no offence) its probably just set up badly, get some one who knows what there doing to play with the set up for you, unless you have the cash to splash on getting it set up on a dyno (no point at that stage of tunning)
they say the good die young... i say we just live faster
tutton
PostPosted: 16:46 - 28 Jun 2008    Post subject: Reply with quote
People these days always wanting to go faster.
my geared 50 is only doing 45 atm but ill get over it.
I havnt yet been shown up by a ped doing 60 but id like to see one just to see how bad he kains me Wink
There is a gap of 4 years, 302 days between these two posts...
srdszabolcs
PostPosted: 17:39 - 25 Apr 2013    Post subject: Problem Reply with quote
Hi. I have a Peugeot Speedfight 2001. Problem is, that there is electricity in the gas cable. Dont know how. If I start the engine , and i move the cable, it sparks on the where the cable is connecting vith the right mirros, where the starter, and the lights switchs are, and it stops imediatly. Please help.
Linux
PostPosted: 17:56 - 25 Apr 2013    Post subject: Re: Problem Reply with quote
Make a new thread here
And use this when making the new thread
Two wheels are all I need.
There is a gap of 198 days between these two posts...
benjaimin
PostPosted: 22:58 - 09 Nov 2013    Post subject: Reply with quote
The best thing to do it to check if the variator is rectricted or not you can tell as soon as u look at it when u take the cover of. Also check the exhaust that may still be restricted. It does sound like your exhaust is still restricted however if you revs are still restricted you may as well de-restrict ur cdi as well
ben.dolling
The last post was made 12 years, 85 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 87.13 Kb
