Few questions on safety vs legality
Pie-Roe
PostPosted: 20:30 - 25 Jun 2008    Post subject: Few questions on safety vs legality Reply with quote
Hi all, since the loss of my MZ (too slow and not really my cup of tea, sold it to a friend a fortnight after buying) I've been looking at damaged 400-1200s to buy as a project to slowly build up and possibly 'streetfighter' (only in the way that I want it nekkid and a solo subframe)
I have come across a fair few, but I have some queries.
I know how the CAT system works, and which ones you can buy (C+D IIRC) so thats not a problem, however.
1) if a frame is cracked is it illegal? Secondly if it isn't illegal then is it safe, 1/3 of the width?
2) bent forks, Obviously they can't be rebent, but are a lot of them interchangeable or is it only a select few?
3) Swingarm cracks? Full replacement?
4) twisted yokes? Will have affected the frame?
5) I've found a couple of bikes stolen recovery, which are pretty cheap, no loom at all. Can you make a loom out of several other looms?
Cheers for any replies Karma
Pyro
PostPosted: 20:38 - 25 Jun 2008    Post subject: Re: Few questions on safety vs legality Reply with quote
Most likely illegal to use under construction & use regs. Definately stupid to ride with a fractured frame. Not safe at all.
You can straighten fork stanchions or just buy new ones. Fitting good used ones is preferred.
You can weld most things that are cracked, swingarms included. Have to be assessed on a 'per-case' basis.
If the forks are just twisted out of line then you should loosen everything and pull them back straight. Better yet pull the front end off and inspect it all then it will re-build straight if the forks aren't bent.
Not somethng I would reccomend attempting. Buy a loom from a smashed bike is the best idea.
Pyro
Robby
Dirty Old Man
PostPosted: 22:19 - 25 Jun 2008    Post subject: Reply with quote
In any project like that, it wouldn't be economical to put the bike back on the road, much cheaper to buy a tatty runner in the first place if you're just going to rip bits off/rat it.
Remember, bikes are pretty cheap, but bike spares are horribly expensive. Knackered bikes are worthwhile for spares, or for making one good bike out of two or 3 dead ones. Even then its only worthwhile if you get the dead ones for free or close to.
Fagin
PostPosted: 23:05 - 25 Jun 2008    Post subject: It all depends... Reply with quote
Have seen some class bodges in my time having survived the 70's bikes.
Some of the bodges were surprisingly robust and lasted longer than the rider quite often.
Have seen people weld swinging arms (they were generally just stell then).
Forks used to be "rolled" back to straightness - unless creased in which case no use.
Exhausts fixed with old bake bean cans.
Baffles welded or rivetted back in.
Frames - if head stock bent people often did cut out part of the frame and weld in straight or add new parts, often it was a good fix - as long as you didn't think about it too much. (Remember people were often cutting up Norton Featherbed frames and fitting Rover engines in them and then re welding them).
My brother had a bike that used to love left hand bends - (even ones that weren't there) but used to have to fight it round right handers. All because it had been pulling a side car for years until and accident smashed to sidecar up and bent the frame.
Nowadays bikes are so much faster and therefore much more sensitive to change that unless your looking at an old veteran or a Beemer maybe it probably isn't worth the effort?
The last post was made 18 years, 105 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 43.34 Kb
