OK... so that was a VERY bad idea!
Thom
PostPosted: 17:41 - 26 Jun 2008    Post subject: OK... so that was a VERY bad idea! Reply with quote
Erm, don't put any amount of fuel directly into the carb because it just backfires and goes bang.... really loudly... Oh and then catches fire in the air box...
Infact, REALLY REALLY loudly...
Any idea for getting a bike started of which has a spark (obviously!)
And it's getting fuel...
And air....
Hmmm
Thom
PostPosted: 17:53 - 26 Jun 2008    Post subject: Reply with quote
I'm thinking it could be too much redex, so im getting a gallon of fuel in a while, see if it helps at all!
virus
PostPosted: 19:34 - 26 Jun 2008    Post subject: Reply with quote
If its got a spark at the right time, compression, and fuel it should fire, it may not run right but it will fire.
Too much redex shouldn't cause that to happen.
John
own: 81 xs1100g...
Thom
PostPosted: 22:14 - 26 Jun 2008    Post subject: Reply with quote
it seems to eb running now, but god knows if it'll run come morning, im getting up early, giving it a good 30mins warm up at idle and then going for my MOT, if i make it thats a weight off my shoulders, if i dont, i'll try and sort out the problem before i next book.
binge
Emo Kiddy
PostPosted: 22:19 - 26 Jun 2008    Post subject: Reply with quote
Leaving a bike running for half hour on tick over will do it no good at all.
PostPosted: 05:33 - 27 Jun 2008    Post subject: Reply with quote
If you've ignited fuel-air in the airbox either your ignition or cam timing is out causing the spark to happen when the inlet is open or one of your inlet valves is bent or burnt causing combustion to ignite whats in the airbox.
Making the engine run by pouring fuel into the hole is not a cure for your problem, you need to find and fix the problem then the engine will run properly as a by-product.
Thom
PostPosted: 05:38 - 27 Jun 2008    Post subject: Reply with quote
wey not half an hour perhaps, it gets warm pretty quickly.
Once i've passed/failed today i'll have a look at the ignition timing see how it is, if thats alright i'll check the cam.
more questions to follow then!
The last post was made 18 years, 96 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 53.15 Kb
