 boredatwork Nova Slayer
 Bezzer World Chat Champion
 Posted: 12:04 - 27 Jun 2008 Post subject: |
The exhaust bolts can be a bitch to get off, but mine aren't I take them out every few months and copper grease them
Use Plusgas not WD40 much better stuff and have a go at them straight after it's been running so it's nice and hot, wear decent gloves though. If the standard hex key starts to round them off next step if to bang a torx bit in and try that. When you've rounded the inside hex then the ultimate removal method is to get a multipoint 1/4" drive 12mm socket and bang it over the bolt head, it's spot on size to dig into the outsides of the bolt then use a ratchet to undo, works in most cases.
You might get lucky and they come out easy depends when they were last taken off. The bolts are M8 25mm long if you're going to replace them.
Banditmania do a good job on the exhaust repair but it is expensive, mate took his to a local stainless welding firm and they did it for a tenner, they only have to weld a stub of 60mm stainless tube inside it. ____________________ I used to be indecisive but now I'm not quite so sure. |
 SonicTheHedge... Nitrous Nuisance
 Posted: 12:34 - 27 Jun 2008 Post subject: |
It's (IMO) worthwhile getting a new stainless system, as you'll just be able to ignore it from then on, or, failing that, see if you can find replacement downpipe/collector/linkpipe assemblies that let you keep your silencer, as that might be cheaper.
As long as you use plenty of penetrating oil over plenty of time (mine took 3 days of torture) you should be able to get 'em out - it's the right combination of brute force and gentleness.  ____________________ Previous: '00 G2 Bandit 600 Naked. Now: '08 BMW GS Adventure. |
