help help!
zxcvbnm
PostPosted: 15:24 - 28 Jun 2008    Post subject: help help! Reply with quote
yea yesterday i wanted to go out and drive my dirt bike. but when i wheeled it back ward to turn it a around the back wheel locked up!! so now my back wheel is still locked up and i dont no what to do. and i also noticed before this happened that the back wheel wasvery hard t turn but i could still drive it. do you think i could be my drum brakes sticking? any suggestions onwhy my back wheel is locked up?????????????
ride it like you stole it!
Finglonga
PostPosted: 17:00 - 28 Jun 2008    Post subject: Reply with quote
Lift it onto a crate and remove the back wheel, then strip the drum down to see if it is that causing the problem.
Andy Sez....
F.Y.Y.F.F.
Fagin
PostPosted: 17:11 - 28 Jun 2008    Post subject: What make of bike is it? Reply with quote
Is it shaft drive, chain etc?
How old is it, who serviced it last?
You mention drum brake, do you know how to adjust this? At a guess it may just need backing off on the adjuster but if its covered in crud then it will probably need a bit of a clean and inspection.
Its usually not too bad a job.
Start with a good clean of the bike paying particular attention to the rear wheel obviously, to look for any visible damage.
Next try slackening off the brake.
To do this - firstly press down on your back brake lever and watch for movement at the back wheel - (if there isn't anything moving then chances are its seized) - assuming its a metal rod type there will be a nut on the end of this rod, slacken that off and see if you regain any movement in your wheel.
If not then you will probably have to take the back wheel out and visually check the brake shoes, do you know how to do this?
The last post was made 18 years, 76 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 35.78 Kb
