Very Fing stupid think todo....
EssexNSR
PostPosted: 05:13 - 30 Jun 2008    Post subject: Very Fing stupid think todo.... Reply with quote
Right i know im going to be called a idiot, muppet, stupid wan***r and so on.
Id just finished draining the oil on my NSR 125 and getting ready to put the new oil in, so i put the sump plug bolt back in and began to tighten it up, mate came to my house at this point (was doing it in the front garden) when i tightened the sump plug to tight, IT SNAPPED ! inside the engine, Now i need away to fix this. The plug thread is still inside the engine.
i think a engine rebuild would sort this out ?
anyone had this problem before ?! best way to sort it out please.
all help appreciated.
Bike - Honda NSR RX 125cc
hmmmnz
PostPosted: 05:46 - 30 Jun 2008    Post subject: Reply with quote
pop the sump off and see if you get any purchase on the inside and keep screwing it through.
or unscrew it the way it went in.
thats hardly a reason for a engine rebuild, or something you'd even consider when doing a rebuild.
if you still can't get it, then you will have to drill a small hole in it and use a bolt extracter set,
or take it to your local welders and get them to weld a small bit of metal to it so you can unscrew the broken bit...
have fun
Very Happy
the humans are dead
I kick arse for the lord
EssexNSR
PostPosted: 05:57 - 30 Jun 2008    Post subject: Reply with quote
the thread thats snapped inside the engine is about 2/3 inches inside, forgot to mention that
PostPosted: 06:27 - 30 Jun 2008    Post subject: Reply with quote
If you've got a dremmel you could make a slot that you could fit a flat head screw driver in.
Ben.
PostPosted: 13:04 - 30 Jun 2008    Post subject: Reply with quote
engine out sump off, new sump in
or grind a slot into it, flat head screw driver, mole grips, weld a bolt onto it, drill it out and use an extractor thingy majig. Thats the lot really.
enjoy Thumbs Up Laughing
follow my racing season
Race bike - R6
Road bike - sv650
EssexNSR
PostPosted: 13:26 - 30 Jun 2008    Post subject: Reply with quote
tryed today with a friend, i dont really have a shed load of tools but we tryed with a flat head, and some one things, went to a garage and asked what we can do, same thing really. or let them do it for alot of money..... got afew tools today and with willpower we should get it done tomorrow, hopefully
PostPosted: 13:28 - 30 Jun 2008    Post subject: Reply with quote
2 stroke so almost certainly no seperate sump. The drain plug probably goes directly into the crankcases.
You might well find that now there is no head on it the bolt is fairly loose it you can get anything to grip it.
dch
PostPosted: 14:19 - 30 Jun 2008    Post subject: Reply with quote
I'd go for the Dremel idea above, but you might also want to look at this:
https://www.jmldirect.com/Screw-Extractor-PS5616/
Given that it can cut into the rounded head of a screw, you might find that it can cut into your sump plug and take it out.
Frost
PostPosted: 14:23 - 30 Jun 2008    Post subject: Reply with quote
Drill a few small hole in it in a line like this:
ooo
so that they overlap slightly, then stick a flat screwdriver in it and unscrew.
ncrn
PostPosted: 14:34 - 30 Jun 2008    Post subject: Reply with quote
The NSR has no sump, if you wanted to replace the case you would have to split the engine in half, no easy job. But if you do decide that is the only option I think I've still got that half of the engine casing that hasn't been sold yet. Unless its on the right side of the engine then no I don't.
PostPosted: 14:40 - 30 Jun 2008    Post subject: Reply with quote
Almost certainly the crankcase halves are a matched pair.
ncrn
PostPosted: 16:08 - 30 Jun 2008    Post subject: Reply with quote
You sure? I got two engines in half at the moment, I know which is from which engine but they look very similar to me.
PostPosted: 16:36 - 30 Jun 2008    Post subject: Reply with quote
Yes, the difference will be very minor but the main bearings positions, etc, and likely to be bored for both cases at the same time. This way they line up perfectly.
Same is done with camshaft caps on 4 strokes.
bladerunner
PostPosted: 08:14 - 01 Jul 2008    Post subject: Reply with quote
If the head snapped off then I'd try either the slotting as mentioned before or even easier Try tapping it round with a centre punch or grind something hard to a point and try that. if you get it to start turning it should come out pretty easy.
PostPosted: 16:32 - 02 Jul 2008    Post subject: Reply with quote
Probably the only situation I would suggest using an easy-out. Drill the plug and wind it out.
The last post was made 17 years, 232 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.37 - MySQL Queries: 15 - Page Size: 87.48 Kb
