bandit idle low
lee8040
PostPosted: 14:03 - 28 Feb 2008    Post subject: bandit idle low Reply with quote
ive just bought a bandit 600 the bike was stalling at the lights today as the idle seemed to low, can this be turned up without using the choke?
it1uk
PostPosted: 14:14 - 28 Feb 2008    Post subject: Reply with quote
Yes, there should be an idle adjustment knob on the left hand side of the bike as you sit on it, should be just sticking out from the bottom of the carbs.
It will have a little black knob on it.
lee8040
PostPosted: 14:16 - 28 Feb 2008    Post subject: Reply with quote
what is the ideal idle speed?
mr.kris
PostPosted: 14:29 - 28 Feb 2008    Post subject: Reply with quote
between 1000 and 1250 whatever ur bikes happy at id aim for 1250 in cold
TS50X---CM125---MZ150---Z250---RS125---ZXR250---BANDIT600---TRX850---TL1000S---CBF600---ZX6R---BANDIT1200S---CG125---VFR800---CBR1000F---CG125---CG125---CB900F---CB900F---CG125---TUONO1000R---KLR600---GSX1300R HAYABUSA---VFR400NC30---BANDIT1200---CG125
HAYABUSA now in use!
Pie-Roe
PostPosted: 17:21 - 28 Feb 2008    Post subject: Reply with quote
Was it thoroughly warmed up? In this weather mine takes a good 5 minutes (1 with choke on then 4ish manually holding the revs with the clutch in at junctions)
If not then there you are, apparenlty carb icing is also a problem. And mine idles at 1300, and still has this problem...
Pyro
antonfrompres...
PostPosted: 17:17 - 02 Jul 2008    Post subject: Reply with quote
I've been having this problem with my bandit and I cannot see a black knob at the left hand side of the bike. There is a black plastic knob underneath the carbs in the center of the bike that is quite tricky to turn due to its position. I turned this and it did alter the idle but is this the correct knob? or is the idle knob really at the left hand side?
boredatwork
PostPosted: 07:51 - 03 Jul 2008    Post subject: Reply with quote
if its a mk1 "old" bandit, then the knob is like an old radio tuning knob -"knurled" is the correct description i think - in the middle of the carbs, yes its a bugger to get to, you'll know its the right one if you burn your arm continously whilst turning it when the engine is warm!
DAS/Test: Passed March 08!
Bikes: CG 125 and k4 750 gsx-r
Bishbash
PostPosted: 12:15 - 03 Jul 2008    Post subject: Reply with quote
Yup it is definately the knob, Turn it clockwise to increase the idle speed, it wont need much turning to increase it, but have a play with it to get it to waht you need.
BB
The last post was made 17 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 55.51 Kb
