Running in, please pass...
Adam_P
PostPosted: 13:56 - 11 Mar 2004    Post subject: Running in, please pass... Reply with quote
on advice to the newbie! Wink
After reading through my bike's manual I'm after some advice on running in.
It states that for the first 600 miles I should not use prolonged use over 7000 revs, then up to 9000 revs after the first service to 1000 miles. Then it should be fine to take it up to the top of the rev range.
When I rode it back home the other day I peaked at just over 7000 on the motorway passing a few things, it equates at about 90mph, so its still getting on a bit and is plenty for me for the time being.
What I really want to know is, 'prolonged use' does that mean occasionally going over 7000 is ok, as long as I don't run it like that for miles and miles. Or, should I keep it under that until the 600 barrier and then let it have its head a little?
What has anyone else done?
I saw the link to the guy in the US that recommends thrashing it from the word go to seal the rings etc early. But not keen on hammering my investment if its going to end up throwing pieces of the engine out of the exhaust as a result. Shocked Wink
Thanks in advance for advice folks.
Colin McRae MBE 1968 - 2007 RIP Sad
Orwell Rolls in his Grave
God is imaginary
Scooby
Scrappy Doo
PostPosted: 13:58 - 11 Mar 2004    Post subject: Reply with quote
Just ride it as if it were a 10,000 mile bike. You shouldn't keep any bike at the same amount of high revs for very long. Modern 4 stroke engines don't really need 'running in'.
dainesefreak
PostPosted: 14:12 - 11 Mar 2004    Post subject: Reply with quote
The camps are split between thrash it and stick to the manufacturers guidelines.
They usually mean that you should vary the revs and not stick to a constant 7k rpm for a long period of time. On my Blade the only recommendations Honda make are no full power starts until first service.
As Scooby said four strokes don't need that much running in these days, if you're worried about it just get the miles out the way and get the first service done. At the end of the day you've got to ride it and keep it so I'd say do what you're happiest with.
Robby
Dirty Old Man
PostPosted: 15:09 - 11 Mar 2004    Post subject: Reply with quote
As long as its warmed up, ride it how you want to.
PostPosted: 15:11 - 11 Mar 2004    Post subject: Reply with quote
I would say aim to keep it below 7000rpm, but don't worry too much if you take it over there the odd time.
The US site was not really advocating thrashing it in but instead riding it in such a way to force the rings into hard contact with the cylinder wall. It will do nothing for anything else that could do with running in (gears, valves, etc).
Also remember that a new bike while running in will land up with a fair amount of small particles floating round in the oil (bits of metal that have been worn off while running in), and it is a good idea to get these out by doing an oil change before pushing the bike 2 much.
Adam_P
PostPosted: 16:00 - 11 Mar 2004    Post subject: Reply with quote
Thanks guys. I'm guessing get it to the oil and filter change at 600 miles before giving it too much to be on the safe side.
That was what I was thinking originally as I knew about the particles and stuff in the oil etc. Wasn't sure about other parts of the engine that might suffer with an occasional blast above 7 grand.
Adam
God is imaginary
Sparks!
Sir Tart-a-lot
PostPosted: 18:52 - 11 Mar 2004    Post subject: Reply with quote
Hmm I've been keeping my R6 below 12k mostly, also making sure its up to temperature before going anywhere fast.
It's on 850 miles now and will start ragging it a bit more after 1000 miles.
Just keep the revs down a bit for a few hundred miles as Scooby said, modern 4 strokes don't really need over-cautious running in.
Mr C
PostPosted: 20:58 - 12 Mar 2004    Post subject: Reply with quote
Mine went through the timing lights at Elvington at 173 at the 1000 miles exactly
fuck it, they need thrashing - that pathetic speed proves it
187.3bhp = 201mph
PostPosted: 17:00 - 13 Mar 2004    Post subject: Reply with quote
Ride it to full revs, but don't ride it on constant throttle. vary the revs a lot and it should be fine. Ride normally after the first service! Thumbs Up
The last post was made 22 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.87 - MySQL Queries: 15 - Page Size: 61.81 Kb
