GPZ stiff in morning
largeinnit
PostPosted: 14:00 - 11 Mar 2004    Post subject: GPZ stiff in morning Reply with quote
Hi,
I've noticed that my kawasaki gpz 500 is very difficult to push first in neutral thing in the morning (when I get it out of the garage) as if the front break pads are stickin or it needs lubricating.
The funny thing is once its been riding for a bit it moves along fine without much resistance? Anyone else have this problem and how do you resolve it (if necessary)?
I'm not sure, but I guess some rust/dirt deposits are building up over night/ extended periods of non use.
thanks in advance
large
if you understand what you're doing you're not learning anything
Scooby
Scrappy Doo
PostPosted: 14:12 - 11 Mar 2004    Post subject: Reply with quote
Probably the seals are restricting the movement of the pistons. Only thing you can do is strip the calipers down and overhaul them, replace the seals with coppergrease. As a quick fix just give the calipers a whack with a mallet before you move the bike and it will free them off a bit.
ZaphodBeeble
PostPosted: 11:13 - 12 Mar 2004    Post subject: Reply with quote
It could be your gearbox oil getting really cold and causing it to be really thick. Even in neutral it could feel like the brakes are on. When the bike is warm the oil is thinner so the problem disappears. Thumbs Up
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
Scooby
Scrappy Doo
PostPosted: 11:14 - 12 Mar 2004    Post subject: Reply with quote
That's got nothing to do with it.
PostPosted: 11:27 - 12 Mar 2004    Post subject: Reply with quote
The drag from cold oil will be there, but is so minimal that you are unlikely to notice it. Bit like the difference in effort to swing your leg through the air between a day with high air pressure and a day with low air pressure.
Front brakes sticking is the most likely cause. Probably the seals, but possibly just the pins it slides on (GPZ500 uses a twin pot sliding caliper). Giving the caliper a good clean will probably help (use a tooth brush and then cotton buds to clean the pistons), but the real solution is to rebuild it with new seals.
One other possibility is that you have an aftermarket cast iron disk. These can easily stick to the pads over night, especially with sintered pads.
If the problem is not coming from the front the also check the chain. It it is really bad, or the sprockets are really hooked then it will cause problems. However you would have loads of other problems if this were the case.
largeinnit
PostPosted: 11:07 - 13 Mar 2004    Post subject: Reply with quote
Thanks for the info guys.
I do have a cast iron disk, I'll try cleaning the calipher first and if that doesnt work I'll take a look at the seals.
The last post was made 22 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 47.88 Kb
