r6 service parts and times?
gray84
PostPosted: 22:04 - 03 Jul 2008    Post subject: r6 service parts and times? Reply with quote
hi had my r6 a month now and its done 10k and got service history all over the place but dont say what its had done.
what should be done and when? plugs,carb set up,air filters ect.
cheers for any info in advance
gray
iooi
PostPosted: 05:08 - 04 Jul 2008    Post subject: Reply with quote
I always tend to give any bike a buy a good service. Just so you know that its all OK.
Certainly change plugs and oil. Air filter have a good look at, same with brakes and the rest.
gray84
PostPosted: 16:03 - 04 Jul 2008    Post subject: Reply with quote
what sort of price am i looking at to pay at a small local bike garage to do the works on it. ill get it donw within the next few hundred miles.
Scouse
PostPosted: 16:19 - 04 Jul 2008    Post subject: Reply with quote
Probably around £100-£150, depends on the garage really.
TUG
PostPosted: 19:43 - 04 Jul 2008    Post subject: Reply with quote
Usually its chain adjusted, lubed, tyre pressures corrected, oil and filter change, then any other consumables, at a set mileage.
Normally things are replaced when they have been inspected and are no longer any use. Theres no set in stone as it were things.
Haz ER-5, innit!
iooi
PostPosted: 20:12 - 04 Jul 2008    Post subject: Reply with quote
Well if you ask them they will tell you Rolling Eyes
Crystal ball ain't working too well at the moment.
Ask them what they will do, for the price they say. Or tell them what you want doing and ask how much.
Oil, filter and brake pads are easy.
gray84
PostPosted: 20:46 - 04 Jul 2008    Post subject: Reply with quote
well iv only just got the bike and into the biking scene really. so not sure what can/should be done. i want the works done so i know its all fresh and good.
oil and filter
air filter
brake fluid
carbs set up
plugs new or adjusted
and a good check over
what else?
cheers
iooi
PostPosted: 07:28 - 05 Jul 2008    Post subject: Reply with quote
To be honest start to learn how to maintain the bike by doing the oil, filter, air filter and new plugs yourself. All are very easy jobs to do.
Brake fluid should be fine. Unless you feel the brakes are really spongy and then it might be better to get the std lines replaced with something like these Its usually the rubber lines that are the problem.
A carb balance well unless you have the kit a shop is the best place.
gray84
PostPosted: 22:22 - 05 Jul 2008    Post subject: Reply with quote
got a price from a local small garage today and it was £230 is that a bit much for what i listed?
i may consider doing it all myself if its gona cost that much. only expected £150 ish
The last post was made 18 years, 112 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 59.15 Kb
