SRX600
Frost
PostPosted: 16:44 - 05 Jul 2008    Post subject: SRX600 Reply with quote
After owning a few different bikes with peaky power delivery i decided i wanted something different. I went for the SRX as it looked to be a good commuter and distance bike with some character. Bought on ebay for £450.
https://users.aber.ac.uk/mrb6/SRX/right.jpg
The bike was low milage, had brand new tires, K&N filter and an aftermarket road legal exaust system, but had been stood for 8 years.
https://users.aber.ac.uk/mrb6/SRX/back%20left.jpg
https://users.aber.ac.uk/mrb6/SRX/left.jpg
https://users.aber.ac.uk/mrb6/SRX/tire.jpg
https://users.aber.ac.uk/mrb6/SRX/back.jpg
https://users.aber.ac.uk/mrb6/SRX/can.jpg
https://users.aber.ac.uk/mrb6/SRX/pipes.jpg
After many hours spent trying to get it to start i discovered it had a blocked pilot jet and as a result wouldnt run below 3k rpm. That problem fixed i started to ride the thing. From very early on it was pissing out oil. After many hours checking various seals i discovered the oil was actually coming from the airbox Confused The crank case breather was spitting out loads of oil. The bike also strugged greatly to get to 70mph. I concluded this meant that the rings were worn and that it would need a strip and top end rebuild.
The side stand was attached to a section of lower frame that had to be removed to get the engine out, so carefully the bike was placed on its side.
https://users.aber.ac.uk/mrb6/SRX/DSC00262.JPG
As usual most of the exaust studs were totally fucked, 3 out of 4 sheering off, the other unscrewing the whole stud.
https://users.aber.ac.uk/mrb6/SRX/DSC00261.JPG
The Top end was removed and cleaning began.
https://users.aber.ac.uk/mrb6/SRX/DSC00260.JPG
The standard barrel size as a 96. This one has a liner in it marked 97. What do you guys think to the state of the barrel & Piston?
https://users.aber.ac.uk/mrb6/SRX/DSC00268.JPG
https://users.aber.ac.uk/mrb6/SRX/DSC00265.JPG
https://users.aber.ac.uk/mrb6/SRX/DSC00266.JPG
https://users.aber.ac.uk/mrb6/SRX/DSC00267.JPG
Going to get it bored out to a 98 & get a new Wiseco piston bumping the engine from a 608cc @ 8.5:1 to 633cc @ 10.5:1.
The bike has a dry sump with oil cooler and external oil tank. Inspecting the crank case showed it was FULL of oil. I think i've drained 3 litres out of it! Confused
https://users.aber.ac.uk/mrb6/SRX/DSC00263.JPG
No idea quite how the case has acumulated that much oil but i suspect either the oil pump is fucked, or the oil strainer is blocked. Inspecting these will envolve splitting the crank case, which first requires the removal of the flywheel, something i am definatly struggling with! Any tips or diagnosis would be apreciated.
https://users.aber.ac.uk/mrb6/SRX/DSC00264.JPG
yankeedoodle
PostPosted: 17:10 - 05 Jul 2008    Post subject: Reply with quote
nice.love the yellow.dont see many srxs around so its something a bit different!
Bandit 600
twotakt
PostPosted: 17:11 - 05 Jul 2008    Post subject: Reply with quote
Sorry I can't help you with the issues the bike has, but it looks a nice bike. It slightly reminds me of the Yamaha SDR200
https://i276.photobucket.com/albums/kk15/jackdim/bikepics-467089-full.jpg
R.I.P. Tareree Shiimi, 1985-2008
Frost
PostPosted: 18:19 - 05 Jul 2008    Post subject: Reply with quote
No sure what to do with it once its all working...if it ever gets all working!
Gazdaman
I did a trackday!!!
PostPosted: 11:16 - 09 Jul 2008    Post subject: Reply with quote
Flywheels are a bugger. In the past I've used a claw puller.
The trick is to get a decent amount of tension behind the puller then smack it with a hammer and shock it off.
Have you got a haynes manual for it?
Gaz
PostPosted: 13:31 - 09 Jul 2008    Post subject: Reply with quote
My vote is for a Kenny Roberts themed Cafe racer.
Rowey
PostPosted: 13:41 - 09 Jul 2008    Post subject: Reply with quote
That cafe is tasty +1
ZX6R C6F.
Frost
PostPosted: 15:38 - 09 Jul 2008    Post subject: Reply with quote
weee
Frost
PostPosted: 22:21 - 11 Jul 2008    Post subject: Reply with quote
weee
Fnatic
PostPosted: 00:47 - 12 Jul 2008    Post subject: Reply with quote
Sounds like a good project mate with a really good write up. Keep it up. I am enjoying reading it Thumbs Up
Gazdaman
I did a trackday!!!
PostPosted: 08:27 - 12 Jul 2008    Post subject: Reply with quote
Nice job!
For the piston rings, I'd get a piston ring compressor, although you can do it with a steady hand. It's one of those tools you'll buy once, but have forever more just sitting on a shelf waiting for you to next need it.
And you can re-cover seats yourself, but they'll normally look crap. So I'd get it done by a pro, especially if you want the hump put in.
Go to a local upholsterers, needn't be a specialist seat place.
Gaz
virus
PostPosted: 08:30 - 12 Jul 2008    Post subject: Reply with quote
Good work, You certainly know what your doing by the looks of it. Thumbs Up
Will be interesting to see the final product.
John
own: 81 xs1100g...
reu
PostPosted: 15:06 - 12 Jul 2008    Post subject: Reply with quote
Looking good Thumbs Up will be looking foward to seeing it totally finished.
125cc Pitbike <sold> Aprilla Mx50 <current>
Frost
PostPosted: 14:50 - 18 Jul 2008    Post subject: Reply with quote
weee
MaybeGuy
PostPosted: 15:15 - 18 Jul 2008    Post subject: Reply with quote
its never simple is it Laughing
something bad ALWAYS happens.
Frost
PostPosted: 16:16 - 18 Jul 2008    Post subject: Reply with quote
https://ecx.images-amazon.com/images/I/4101GVVH0NL._SL500_AA280_.jpg
It's not happening again Razz
colin1
Captain Safety
PostPosted: 01:17 - 20 Jul 2008    Post subject: Reply with quote
This is all very thorough for something bought on ebay for £450.
Scouse
PostPosted: 14:51 - 20 Jul 2008    Post subject: Reply with quote
Well it might as well all be done/checked/sorted whilst it's apart hadn't it.
Frost
PostPosted: 17:29 - 20 Jul 2008    Post subject: Reply with quote
Initially i effectively had a non runner as it took up to an hour to get it started, then it ran like a bag of arse. I've not started work yet so have plenty of free time. So far i've spent about £100 on it and now have a mechanically sorted bike that starts first kick.
Clip on's are on order along with a master cylinder repair kit, fork seals and mirrors. Going to polish it up, respray it and have a bike that is then worth double what i paid for it Laughing
petemell
PostPosted: 22:31 - 01 Aug 2008    Post subject: Reply with quote
Is the exhaust the Predator type? And is it the complete system including the down pipes. It is a smart bike.
Frost
PostPosted: 11:06 - 02 Aug 2008    Post subject: Reply with quote
Yes its a predator road legal system. The down pipes slot into it under the bike. My down pipes are stainless steel so i think i have the whole system. You could probably get the end can and cut down your original down pipes to fit?
The can sounds nice and deep for a legal system.
Frost
PostPosted: 19:15 - 02 Aug 2008    Post subject: Reply with quote
Whoops.
Frost
weee
Mac_Black
PostPosted: 04:48 - 03 Aug 2008    Post subject: Reply with quote
haha Massive double post.
Nice project so far.
It will be great to see this getting along.
quacker_boy
Cuddle Bitch
PostPosted: 06:41 - 03 Aug 2008    Post subject: Reply with quote
DaFrostyOne wrote:
I replaced the dust seals on the forks
Hang on, you only replaced the dust seals or replaced the oil seals as well?
Either way, you've made me shit jealous and want to buy another non runner and strip apart and rebuild.
Top job mate, looking forward to seeing the paint Thumbs Up Karma
The last post was made 18 years, 80 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 126.39 Kb
