Speedfight now does 24 ! up from 10, more help needed
motocraft
PostPosted: 16:20 - 06 Jul 2008    Post subject: Speedfight now does 24 ! up from 10, more help needed Reply with quote
Been repairing & biking for a few years now but this has me stumped so far Exclamation
I bought a non runner speedfight 2 & after putting a battery on it & refitting the exhaust boy was it slow Shocked it s better with its new variator but still slow acceleration & top speed so , so far this is what i have done & found
Fitted new polini variator with the lighter rollers
Checked & cleaned jets - main #72 & pilot # 42
Needle position unknown
Added a polini pod air filter
Found a yellow contra spring
Decoked it
Checked the tecnogas pipe dosent have a restrictor in.
The malossi belt "looks" Ok
Clutch bites OK, so i just deglazed it.
Reeds look Ok ( can see real tiny amount of light through the "lip" of one only but the reed seats are poorly finished with a rubber coating that less than perfect so looks standard.
I get plenty of induction roar & its seems like it isnt revving out , also theres some drag in the gearbox / relay noticed when belt was off, does 20 or 24 on a flat , starts ok hot , cold it wont start unless filter is crushed ( thats my manual choke ! )
Anything i have missed Question
'01 Speedflight II, '03 Senda 100, '05 Crf250X, '83 C90
baldy
PostPosted: 19:27 - 06 Jul 2008    Post subject: Reply with quote
I bet if you put the standard air filter on it would work fine. The K&N style filter is making it run stupidly lean. I had the exact same problem on my speedfight after the chav i bought it off decided to try and ''de-restrict it''.
I think the needle should be in the second from the top notch.
One day i will rule the world, just not today.
PostPosted: 20:00 - 06 Jul 2008    Post subject: Reply with quote
I doubt the pod is making it run lean especially with a 72 main jet.
motocraft
PostPosted: 21:29 - 06 Jul 2008    Post subject: Reply with quote
It came with no filter at all or any pipework or airbox etc.. could be lean , i havent done a plug chop yet,
Whats the standard main jet size ?
How long do you have to run it for before the plug chop test gives a " true " colour ?
Can a plug chop test be done by running the bike on a stand ? its far from road legal yet Twisted Evil
motocraft
PostPosted: 21:32 - 06 Jul 2008    Post subject: Reply with quote
Baldy, i will try the needle on the richest setting tomorrow to see if that helps.
PostPosted: 21:59 - 06 Jul 2008    Post subject: Reply with quote
As far as I know the standard main jet is around 60ish.
Maybe try joining the Pug Club, they'll know a lot more.
Clicky
rezzin
PostPosted: 22:58 - 06 Jul 2008    Post subject: Reply with quote
Sparkplug or filter id bet. Thumbs Up
motocraft
PostPosted: 08:20 - 07 Jul 2008    Post subject: Reply with quote
Clicky
pug club sounds good thanks...
motocraft
PostPosted: 08:22 - 07 Jul 2008    Post subject: Reply with quote
Cant be the plug, a plugs ultimate test ( in anything other than race engine) is to start the bike, & it does this fine & runs fine..
motocraft
PostPosted: 08:25 - 07 Jul 2008    Post subject: Reply with quote
standard main is 72 & top position on needle ( weakest ) so looks like lean at mo.
Will order an 82 & go from there..
sieversrichie
PostPosted: 10:13 - 07 Jul 2008    Post subject: Reply with quote
Too much air getting in. Ie. too lean
Try bigger jets or the standard airbox.
The last post was made 18 years, 132 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 69.39 Kb
