| stirlinggaz |
 stirlinggaz World Chat Champion
| virus |
 virus World Chat Champion
 Posted: 21:37 - 06 Jul 2008 Post subject: |
Take your switchgear apart again and check the cable returns, pull it (probably need pliers, it will be quite stiff) and let go, if it snaps back you can rule out cable/carbs.
If its not the cable/carbs, then make sure your clipon is clean on the part where the throttle tube goes, then put it all back together, if this doesnt fix it then it will be down to your grip touching either the switchgear or the barend, this requires careful pulling into the right place or a washer to move the bar end out a bit.
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| stirlinggaz |
| virus |
 Posted: 21:54 - 06 Jul 2008 Post subject: |
more than likley, happens to my bike quite often, easy as hell to fix though.
| Joeb46 |
 Joeb46 Traffic Copper
| Ste |
 Ste Not Work Safe
 Posted: 21:21 - 07 Jul 2008 Post subject: |
Try spraying some spray grease between the plastic throttle tube and the clipon.  |
| stirlinggaz |
| Thom |
 Thom World Chat Champion
 Posted: 06:25 - 08 Jul 2008 Post subject: |
sounds like you just pushed the grip on a little too far and its rubbing against the switch gear, move it back so theres about 1-5mm between the grip and switchgear and youll be sorted
very much like virus advised  ____________________ Current Bike: 1996 Yamaha TRX850 (The Japanese-Ducati One).
Previous Bikes: 1990 Honda NSR125 'Rothmans' (The smoking one), 1990 Suzuki GS500e 'Caf? fighter' (The loud one), 1987 Kawasaki GPX400r (The quick one), 1997 XJ600s Diversion (The reliable one), 2000 Kawasaki ER-5 (The spontaneously combustive one) |
| virus |
 Posted: 09:08 - 08 Jul 2008 Post subject: |
| stirlinggaz wrote: | | Joeb46 wrote: | cruise controll.... stop complaining...
id say they are cathing on the switch gear or the end of the bars.
are you sure you didnt bend the carb needle when you put it back together? |
cruise control.. lol
carbs fine, definately the grip.
not catching on the switch gear, no bar end so i can only presume the plastic throttle tube is somehow catching on the end of the bar???
& i put some grease on the bar before i put the throttle back on.
1 day & im kinda used to it,but i guess i should sort it, in case i sell it or i forget.
cheers,
GAZ |
That will be it, the grease will clog it up.
It doesnt need any lubricant, best bet is to take the throttle tube off, clean it up then put it back together.
The last post was made 18 years, 96 days ago. Instead of replying here, would creating a new thread be more useful? |
