help oil leaking
zxcvbnm
PostPosted: 00:22 - 08 Jul 2008    Post subject: help oil leaking Reply with quote
yea there is engine oil leaking around the bottom of the fly wheel. its only leaks when runing, when te engine is off it doe not leak. it leaks about a drop every minute. and i have to put oil in more then usual. i bought the bike like this. does any one no why it is leaknig???????????
ride it like you stole it!
MaybeGuy
PostPosted: 02:44 - 08 Jul 2008    Post subject: Reply with quote
there shouldnt really be any oil in with the flywheel (AFAIK).
could be crank seals? if so, its a big job.
is it that bad? could you just live with it?
zxcvbnm
PostPosted: 14:18 - 08 Jul 2008    Post subject: leaking oil Reply with quote
yea theres this thing under that i think holds it on. the thing is shaped like a trangle and at each corner it as a philips screw. the bottom screw is were the oil is coming from. and the past owner must of had the chain fly off at high speed driving and some of the casing is brokon do u think that maybe the couse?? and do u need specheal tools to remove the fly wheeel?? any suggtions pelaple??
MaybeGuy
PostPosted: 14:27 - 08 Jul 2008    Post subject: Re: leaking oil Reply with quote
you will probably need a flywheel puller, and something to lock the flywheel as you loosen the centre nut.
what bike is it?
cracked engine block is possible with a snapped chain flying off.
PostPosted: 14:34 - 08 Jul 2008    Post subject: Reply with quote
Presume this is your XR100.
Not 100% sure, but it wouldn't surprise me if the flywheel cover does hold some oil.
Likely that all you need is a replacement gasket for that cover.
zxcvbnm
PostPosted: 14:55 - 08 Jul 2008    Post subject: leaking oil Reply with quote
the bike is a 2000 honda xr100 i also there is blue smoke coming out of exsust do u think rings are gone are some thing else?? and could i replace them my self if i boought a sevrece or repair manual for the bike? beocue howm much do u think it will cost me if i pay a honda place to replce them???
PostPosted: 15:11 - 08 Jul 2008    Post subject: Reply with quote
Don't know enough about that engine. However quite possible it is one of Hondas pushrod singles which would be pretty simple to strip down. If it is one of the overhead cam engines it will be more difficult, as you will need to set the cam timing correctly. Would suspect the engine might need to come out to take the barrel off to do the piston.
If it is just the gasket that is required then that will be cheap to buy new from Honda and very easy to replace.
The last post was made 18 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 55.29 Kb
