Two Wheel Drive Motorbikes!!!
hopoffbaby
PostPosted: 21:04 - 12 Mar 2004    Post subject: Two Wheel Drive Motorbikes!!! Reply with quote
As i was casually browsing the internet i found something about yamaha releasing a two wheel drive bike in 2004!! Shocked
*See it here*
Noggin
PostPosted: 21:08 - 12 Mar 2004    Post subject: Reply with quote
I heard about this in mcn a couple of months ago now, it sounds good on that link of yours. Will do great in trials etc. I want to know how it will affect sports bikes and things, should find out soon though
Craig G (Noggin)
Current bike: kawasaki zx12r 2002
Track bike: yamaha r6 1998
Old Bike: honda NSR 125 1998
McJamweasel
BCF Junkie
PostPosted: 21:09 - 12 Mar 2004    Post subject: Reply with quote
tests on an R1 1000cc supersport road bike have shown an incredible speed differential on wet tarmac - tests at the tight Swedish Karlskoga roadracing circuit showed the 2-trac-fitted R1 to offer a whopping five second per lap advantage over a standard machine when the circuit was wet.
Blimey.
Although if its that good why are the motogp bikes not already using it?
Noggin
PostPosted: 21:18 - 12 Mar 2004    Post subject: Reply with quote
wow, I didn't read that bit, 5 seconds, thats erm.. a lot! I wonder why they aren't using it in moto GP then...
hmm...
Craig G (Noggin)
Noggin
PostPosted: 21:20 - 12 Mar 2004    Post subject: Reply with quote
hmm...
Craig G (Noggin)
PostPosted: 21:27 - 12 Mar 2004    Post subject: Reply with quote
Probably the extra weight, and the fact that with the front wheel in the air it will still only be one wheel drive.
Sparks!
Sir Tart-a-lot
PostPosted: 21:49 - 12 Mar 2004    Post subject: Reply with quote
OK 2 wheel driving then, so if you do a stoppie..........................................
With perfect balance can you ride it for like, ever? Laughing
nealski
PostPosted: 23:37 - 12 Mar 2004    Post subject: Reply with quote
Yammy put this (or another 2wd) bike into the Dakar and came 8th overall I think. From what i heard it is not going to be used in track racing in the near future, just off road.
Also I believe it is going to be used on mid-range bikes to inspire confidence like ABS.
Formula 1 is RWD, World rally cars are 4wd, I think bikes will follow this patten.
Neal
Nealski
- Dealing with the SSDD
cagiva gezzer
PostPosted: 11:57 - 13 Mar 2004    Post subject: Reply with quote
On a road bike wouldn't you also get problems when leaning the bike over, as the front and rear wheels have different profiles and the wheels would effectively spin at different rates and confuse it.
Thats the main reason why traction control hasn't been fitted to bikes.
Does't matter so much on dirt bikes as its rare to get both wheels in traction at the same time.
IF it had been fitted to a KTM it would of come 1st, not 8th!
G1_
PostPosted: 12:35 - 13 Mar 2004    Post subject: Reply with quote
Cars have the some problem with inside and outside wheels, thats why they have differentials. I expect these bikes will have a similar system.
PostPosted: 12:53 - 13 Mar 2004    Post subject: Reply with quote
Can see where he is coming from. Different makes of tyres of the same nominal size have profiles that vary so the rolling radius will change differently as the bike leans over.
As mentioned cars do have the same problem. Not only between the inner and outer wheels but also between front and rear wheels. When a car is cornering the front wheels travel faster than the rear wheels as they are going round a slightly wider radius circle.
kev
I Hump Things
PostPosted: 12:57 - 13 Mar 2004    Post subject: Reply with quote
Years ago I saw a 2 wheel drive motorbike on tv.
It was a motorcross bike and had a really strange setup with a chain going down from the handlebars.
PostPosted: 17:37 - 13 Mar 2004    Post subject: Reply with quote
AFAIK, the system is only supposed to transfer 30% of the power from the rear wheel to the front, so its not like you'll get problems with cornering really. braking can produce about 55bhp worth of power (according to RiDE a little while ago) so 40 odd BHP probably won't be a problem.
I'd love to have a go! Smile
The last post was made 22 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 77.94 Kb
