hi all
marc_yorks
PostPosted: 19:08 - 13 Mar 2004    Post subject: hi all Reply with quote
Just bought an old ns125f,it go's really well when you rev it Smile
Really surprised me,thing is on low revs it misses and coughs a bit.
do you think it just needs a good tune?
I think its been stood for a long time.
Any help greatfully appreciated. Wink
ZaphodBeeble
PostPosted: 19:15 - 13 Mar 2004    Post subject: Reply with quote
Try cleaning your carbs, get a new spark plug, new air filter etc etc. Thumbs Up
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
marc_yorks
PostPosted: 19:37 - 13 Mar 2004    Post subject: Reply with quote
Cheers for that mate.
Are these pretty easy tasks?
nsr125sp
PostPosted: 20:43 - 13 Mar 2004    Post subject: re Reply with quote
Yea really easy check out https://www.nsr125.com/service.htm for more help Thumbs Up
Ollie
marc_yorks
PostPosted: 20:50 - 13 Mar 2004    Post subject: Reply with quote
cheers menguin Cool
Hex
Party Boy
PostPosted: 10:54 - 14 Mar 2004    Post subject: Reply with quote
The ns air filter is a washable one, so just was it out dry it and i've it a light oiling.
New Spark plug and fresh fuel and away you go. There is nothing below 7000 rev's on them and theres no power valve so it comes in with a rush. Very Happy
Its not the same as the NSR so the manuals and guides don't really apply.
Hex
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
marc_yorks
PostPosted: 14:27 - 14 Mar 2004    Post subject: Reply with quote
Hex
ok mate
we took it apart today,air filter was absolutely past it,spark plug was fine.
weve checked the jets and had the carb apart,blown through them with an airpipe.
still no difference,please tell me are all old ns's like this?
at lower revs its so unsmooth and a bit jerky untill all the power comes in,is this how it should be?
AcIdBuRnZ
PostPosted: 14:48 - 14 Mar 2004    Post subject: Reply with quote
Sounds like you are on the right tracks.
I suggest you send a PM to Kickstart, or wait for him to reply here.
He'll be able to help you, I'm sure.
Good luck Thumbs Up
Mark
marc_yorks
PostPosted: 15:57 - 14 Mar 2004    Post subject: Reply with quote
Good luck Thumbs Up
Mark
Cool cheers
PostPosted: 18:55 - 14 Mar 2004    Post subject: Reply with quote
The older NS has no power valve on UK models. The power valve was a chamber on the side of the exhaust port which (on full power bikes) was open at low revs and closed at high revs. Without a working power valve and with a full power exhaust you will have little low down power, followed by the bike taking off like a scalded cat at around 7000rpm
The air filter might well be a large part of the problem. That would cause it to run rich.
However with a slide carb if you open the throttle fully at low revs you will just drown the engine. You need to open it progressively so that you are only using full throttle at high revs.
The idle circuit and the needle jet control the fueling at up to around 3/4 throttle. It sounds to me like you are running rich so you can try adjusting the mixture. The mixture screw changes the mixture at very small throttle openings. The needle jet adjusts the mixture through most of the range. For minor changes you adjust this by moving the needle slightly. The needle is attached to the slide in the carb, and is located by a clip that goes round one of several notches on the needle. If you move the clip further up the needle (ie, further from the pointy end) then you make the mixture leaner, while moving it down makes it richer.
I would try moving the clip up one notch on the needle and see how that goes.
The last post was made 22 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 67.51 Kb
