Hmm. Think I want a Fireblade...
Mudskipper
PostPosted: 10:05 - 10 Jul 2008    Post subject: Hmm. Think I want a Fireblade... Reply with quote
Well I've been riding the NC29 just over a year now, and for the first time have started thinking about changing it.
I love it to bits, but the wringing it's neck constantly to get the power out is getting wearing, I do weekly long motorway journeys now as well as fun twisty rideouts.
I've always wanted a bigger cc bike eventually, but was hesitant about seat height (5' 1", 28" leg) but now having ridden/sat on various mate's bikes realise that I dont need to flatfoot to feel confident on a bike.
Annnnyway, so I think I want a 90's Blade, cause I love that styling that is similar to my 400. 1995 seems to be what I'm after (style and price wise)
I've done a little reading on models etc, but thought the good people of BCF could perhaps share their experiences/knowledge and hopefully clue me up a bit before I start searching.
Main questions at the moment:
What main differences will I need to get used to going from 400 to 900? Anyone here gone down that path and skipped 600 etc?
I've read there is about 80mm more height on the seat, but is the seat wider than the narrow NC29 seat too? Any shorties ridden/owned a 95 blade?
How is the power delivery different? How does the handling compare?
I assume fuel economy will be worse - but how bad?
Are there common problems with the 95 blades - like the reg/rec on 400s thing etc?
Being fairly common bikes I assume parts (new and second hand) will be easy enough to come by?
Finally how easy are they to work on - access to plugs etc being a nightmare on the 400, is the 900 similar?
Oh and regarding insurance, anyone here 'added' a blade or similar to an existing policy before? Is it the case that the higher CC bike on a multibike policy has to be the main bike, or would I get away with a nominal/admin fee to add a blade (well I can dream!!)
Any thoughts appreciated Thumbs Up Mr. Green
RealNinja
PostPosted: 10:15 - 10 Jul 2008    Post subject: Reply with quote
The 'older' 'blades are physically big bikes, seeing as you are only 5' ish I would think you would have problems.
My wife is the same height as you and she (used to) ride a ZXR400 (H) but couldn't even get anywhere near sitting on my 7, which are similar in size to the older blades.
The problem you are going to have is that not only is the seat height taller, it's also wider (which will take away from your height) and the tank is fatter (which will also take away from your height!).
Me, I would go and sit on one and make sure you feel comfatable with the size and with a bike this big, weight too.
I don't want to put you off, I love FireBlades, but those plastics are expensive!!
You will become my force of retribution. Where you tread, doom will follow. Go now and claim your destiny
craigs23
Mr Muscle
PostPosted: 10:48 - 10 Jul 2008    Post subject: Reply with quote
I went from a RVF400 to a 92 Blade. Not too bad, throttle works both ways, and I adapted to the increase in power and torque quite quickly. The RVF was an awesome pocket rocket, where I could use most of what the bike had to offer on the road, without getting in too much trouble (relatively speaking). The Blade at 7k felt like the RVF at full tap, but the torque was the biggest change - lovely amounts of grunt from the big bore old skool motor. Ultimately, I sold the Blade as I found it a little unsatisfying - the time and place where I could try to use the bike's potential were a lot few and far between in comparison to the RVF. I was also getting too precious about the bike's condition, so traded it for what became my Konica Minolta rep.
See above - in short, more power, more torque everywhere. The gearbox doesn't need prodding as much as the Blade would happily pull from 2.5k, and then take off at 6.5. More power than what's actually necessary, with a lot in reserve too tease cage drivers. Very controllable and predictable, although my Blade shook its head a lot (even when motoring in a straightline), but all old Blades tend to do that.
I'm 5'7 on a good day and didn't find the difference a problem. Did find my Gullarm cramped though. The biggest problem I had with the Blade was the width of its tank, and the bars are a bit of a stretch. You sit in the bike, rather than on it, but that's early 90's seating positions for you.
Not as bad as you'd think, main thing being that the Blade doesn't need revs to cover as ground as quickly. I got around 5mpg difference between the two.
Ebay, Davidsilvers and Wemoto. I doubt you'd need anything else.
GCSE mechanics needed for the Blade, A Level for the RVF. Won't be much difference between the Gullarm and the Blade, but parts are more plentiful, more people know about Blades and there's a lot more space to work on them.
Insurance wise, I went from £120tpft of the RVF to £142 for the Blade. Classic insurance too.
Kal
PostPosted: 11:24 - 10 Jul 2008    Post subject: Reply with quote
I've had a '92 Blade out and it was the least exciting bike I've ridden at legal speeds. Putting through twisties at 60 was a case of leaning casually one way and then equally casually the other.
Gear changes were when I felt I should, rather than the engine requesting it. All in all it felt very lazy.
On the back of the same bike at 120 it became more interesting.
I do have it on good authority that the '92 and '93 Blades are the best to own. Smile
Kal...
virus
PostPosted: 11:27 - 10 Jul 2008    Post subject: Reply with quote
Ive got no knowledge of fireblades, but Id say dont worry about the height.
I seem to remember you handling a Duke very well at R+S, certainly confused a few people. Laughing
John
own: 81 xs1100g...
PostPosted: 11:54 - 10 Jul 2008    Post subject: Reply with quote
Just remember to listen for the cam chain rattle, apart from that at rec-regs they are good.
They shouldn't have been used as race bikes since they isn't a class for them.
craigs23
Mr Muscle
PostPosted: 12:43 - 10 Jul 2008    Post subject: Reply with quote
You'd hear it on pretty much any CBR (gear driven cam 400s aside), they all do that. Best to check it though, but I've only heard of them creating a problem on VTRs.
Second gear usually gets abused too.
Moonie
PostPosted: 13:09 - 10 Jul 2008    Post subject: Reply with quote
*steps in for McGee*
Do eet
Kal
PostPosted: 13:13 - 10 Jul 2008    Post subject: Reply with quote
Points for staying Honda though - you know it makes sense!
Kal...
St0rmer66
PostPosted: 16:55 - 10 Jul 2008    Post subject: Reply with quote
You can handle the powaaa! Go for it if you can get on! Laughing .
:: Honda XR 125 L ('53) => Kawasaki GPZ 500S ('02) => Suzuki SV650S ('00) => Aprilia RSV-R ('51) ::
the grim reaper
PostPosted: 18:05 - 10 Jul 2008    Post subject: Reply with quote
I've had 7 Blades and loved all of them. You can easily get them lowered, it may even be possible by rotating the triangles that mount the shock to the dogbones but you may screw up the rise rate of the rear shock.
Reliability wise, you won't go far wrong, it takes some serious neglect to kill one, however, you're looking at a 13 year old bike, so look for the obvious signs of a dog and budget on having to replace the rear shock etc.
Grim
veeeffarr
PostPosted: 10:45 - 11 Jul 2008    Post subject: Reply with quote
Grim
Do you know anything about 954's? I'm currently looking at some Very Happy
Polo
PostPosted: 10:55 - 11 Jul 2008    Post subject: Reply with quote
I have a 97 Blade and love it.
Boring at low speeds? Laughing
Very confidence inspiring and not a issue to go from a 400. I went from a 125cc.
If you like to hear a engine squeal up near the top end then it probably isnt going to happen. I float around 6-7k. Going above that makes me place another small malteser like object in my kecks.
It has a habit of reminding you what your limits are. Thumbs Up Thumbs Up
Shame you are so far up t'north. You coulda happily taken mine for a spin.
My mum smells your fingers
mark83
PostPosted: 10:59 - 11 Jul 2008    Post subject: Reply with quote
I've often considered a Fireblade but the whole "1000cc IL4 is too much for the road" is starting to sound convincing.
Basically, I like accelerating hard, and you just can't do that on a blade on the public roads!!
Kawasaki ER6n -> Honda CBR600RR -> Honda VTR 1000 -> Moto Guzzi Norge 1200
Buy my Mercedes 350 Sport AMG Evo
Irezumi aka Reuben
Carrot Top
PostPosted: 11:00 - 11 Jul 2008    Post subject: Reply with quote
Do you like riding fast (to the bikes limits) on public roads?
If so then either:-
A) dont buy a bigger sportsbike
or
B) be prepared to pin it and run.
Sitting at half revsin top on my 600 is over the national limit. Sitting at 120-140 on open country lanes is extremely easily done.
Having ridden various bikes, there is no way I could legally run a superbike on the road (not enough self control). Fit an auxillary tank and run it without a plate etc then your talking. Thumbs Up
Hetzer
PostPosted: 11:46 - 11 Jul 2008    Post subject: Reply with quote
Yes you can.
Ghost
PostPosted: 12:01 - 11 Jul 2008    Post subject: Reply with quote
Basically, I like accelerating hard, and you just can't legally do that on a blade on the public roads!!
Edited for you Wink
Mudskipper
PostPosted: 13:32 - 11 Jul 2008    Post subject: Reply with quote
Knew I could rely on BCF!!! Very Happy
Loads of really useful info here, cheers guys. Karma
virus - yeah the Duke was ace, had been putting off having a go for a year cause of the stupid height fear thing. Method was simple - on side stand foot on right peg, into first, then one flowing movement of tilting bike up at the same time as bringing left foot up and kicking stand up, and away!!! Laughing
Tried to wheelie it again last week, but as I was on thick grass it just fishtailed like a bastard Shocked Laughing
Anyway, it all sounds positive so I just need to find one to sit on to be sure I'll be comfortable with the size/weight.
Minty - yeah shame, cheers anyway Thumbs Up Smile
craig - 'controllable and predictable' - sounds exactly what I'm after, with more power in reserve than I would need most of the time. Thumbs Up
I'm leaning towards 92 ones as well but with a mind as to the increased age and wear etc.
Do old blades tend to get traded in much? Wondering if it's worth trawling a few bike shops on the off chance one has one in.
Thanks again all Thumbs Up
Ant
PostPosted: 14:48 - 11 Jul 2008    Post subject: Reply with quote
Grim
Buy one, i travelled to germany (500ish miles) and only had a numb bum for the last hour, i've took it on track days and the misses is fairly comfy on it (for a sportsbike)
For around £4k you'll get a really good example, insurance isnt to bad either
04 ZX10R ~
Polo
PostPosted: 17:22 - 11 Jul 2008    Post subject: Reply with quote
£4000 for a early nineties Fireblade? What is it? A ex-WSB factory one?
Fawbish
PostPosted: 17:51 - 11 Jul 2008    Post subject: Reply with quote
He said 954....2002 onwards I believe Thumbs Up
4K would be a good condition, low mileage model
3K for an average used 954 methinks
Polo
PostPosted: 19:41 - 11 Jul 2008    Post subject: Reply with quote
I stand corrected. Embarassed Thumbs Up
PostPosted: 22:31 - 11 Jul 2008    Post subject: Reply with quote
No way, you'll have trouble finding one for that. The cheapest knackeredest one would be worth £3500 minimum.
Ant
PostPosted: 08:31 - 12 Jul 2008    Post subject: Reply with quote
you'd be lucky to get a track 954 for 3k, not even Marjays smashed up one Wink
04 ZX10R ~
The last post was made 17 years, 356 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 138.68 Kb
