Plaster - Need to smooth it out but it's already dry
Misc
PostPosted: 00:23 - 15 Jul 2008    Post subject: Plaster - Need to smooth it out but it's already dry Reply with quote
Hi, again - Another question if i may.
I routed wires behind the wall for the tv & my plastering skills show up very badly when i've got my neons on behind the tv. I've tried various sanding blocks/paper but the plaster doesn't seem to smooth down to the point where the bumps disappear. What can i do to get rid of them, obviously i don't want to spend much (much as in over a few quid)
Any ideas? Cheers.
https://img133.imageshack.us/img133/9296/image082mk6.jpg
PostPosted: 00:43 - 15 Jul 2008    Post subject: Reply with quote
Could try polycell smoothover.
Like really thick, self-levelling paint.
Frost
PostPosted: 05:04 - 15 Jul 2008    Post subject: Reply with quote
Use coarse sand paper in a power tool. It will level it out, but also scratch up the surface, then smooth it over with finer grit.
bazza
PostPosted: 06:37 - 15 Jul 2008    Post subject: Reply with quote
This should do the trick: https://tinyurl.com/5fh5au
Finglonga
PostPosted: 12:37 - 15 Jul 2008    Post subject: Reply with quote
Best way is to sand it over and skim it again but make sure you don't use a float that is too small as the irregularities won't be covered properly.
Andy Sez....
F.Y.Y.F.F.
Misc
PostPosted: 13:27 - 15 Jul 2008    Post subject: Reply with quote
Cheers guys, i'll go for Stinkwheels method first, if not i'll have to go for the sanding on a power tool. Thumbs Up
The last post was made 18 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 46.77 Kb
