TS50x derestriction
 Topic moved: from General Bike Chat to The Workshop by Korn (18 Mar 2004 - 10:52)
GaZ
PostPosted: 12:55 - 17 Mar 2004    Post subject: TS50x derestriction Reply with quote
Does anyone know how to derestrict these without putting a bigbore kit in it? Confused I've got an exhaust and different gearing and I'm thinking about putting a 75 jet in the carb but other than that I'm stuck for ideas.
Thanks, GaZ
M1ke
Ped Boi
PostPosted: 14:20 - 17 Mar 2004    Post subject: Reply with quote
How fast does it go at the minute?
GaZ
PostPosted: 14:28 - 17 Mar 2004    Post subject: Reply with quote
30-35mph but I know that the back brake is sticking a little bit so I'm hopefully going to sort that out tomorrow (along with a new number plate and brake lever from the last time I decked it Embarassed)
M1ke
Ped Boi
PostPosted: 16:09 - 17 Mar 2004    Post subject: Reply with quote
Probably to gain from the exhaust you do need to rejet. My TS50's were all restricted in the exhaust and in the carb. Also a bigger front sproket helps increase the top speed but slows down the acceleration.
A bike shop would probably derestrict the whole thing for £50 if you are unsure about taking it apart.
cagiva gezzer
PostPosted: 18:22 - 17 Mar 2004    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=16486&highlight=ts50
"because one stroke isnt enough and four strokes waste two"
bikedudextrm
PostPosted: 18:45 - 17 Mar 2004    Post subject: Reply with quote
I've had 2 of them in the past and on both i couldn't find a restrictor anywhere. I've heard that they arn't restricted, maybe the newer models you can but the ones i had were the older ts50x models. My mate has got a H-reg ts50x and he has fitted a 80cc kit, race pipe and a bigger carb. His top speed is only about 45-50mph but his acceleration is pretty good.
The last post was made 21 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.63 - MySQL Queries: 16 - Page Size: 47.42 Kb
