| Misc |
 Misc World Chat Champion
| stinkwheel |
 Posted: 00:39 - 15 Jul 2008 Post subject: |
Ovens go on a high current circuit from the consumer unit.
If there is already a 30Amp socket there, it's fairly self-explanatory.
If there isn't one there, it's a bit more tricky.
It's illegal to do the work yourself without having it inspected by an "expert person".
You can thank whoever it was that voted labour in the last general election for that one. I've yet to track down anyone that will admit to it though. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| iooi |
 iooi Super Spammer
 Posted: 05:20 - 15 Jul 2008 Post subject: |
Many ovens now run through a std socket, rather than the old 30amp wiring.
Personally if the socket is there and you have some suitable/proper wire to do the job, then do it. Your already screwed if you have wired the house anyway...  ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Cigaro |
 Cigaro World Chat Champion
| Misc |
| Stoo |
 Stoo PoshBoy
 Posted: 21:22 - 20 Jul 2008 Post subject: |
You need to work out the total possible load for the oven. In the instructions you'll have the kW rating for each compartment.
Calcs are here https://myreader.co.uk/msg/1391136477.aspx
Cable diameter is here, https://www.tlc-direct.co.uk/Book/4.3.9.htm
Should be carried out by a competant person so says Part P in England / Wales. Might just be a case of buying some 6mm2 cable from B&Q or your local electrical factors. Ovens capable of being plugged in come fitted with cable.
Don't burn your house down / electrocute yourself for the sake of £50 if you don't feel up to it  |
| Misc |
 Posted: 22:47 - 23 Jul 2008 Post subject: |
Thanks for the help, i wired it up today & seems to work fine. There's noway i'd ever pay someone £50 for a small job like that. Pretty simple now i've finished.
Btw, make sure no wires accidentally fall out before you switch it on, otherwise they'll be lots or sparks & smoke.  |
The last post was made 18 years, 86 days ago. Instead of replying here, would creating a new thread be more useful? |
