ages to warm up
lee8040
PostPosted: 07:09 - 25 Jul 2008    Post subject: ages to warm up Reply with quote
my bandit 600 takes ages to warm up i look it in a garage with 2 covers on so it is sheltered from the cold, when i start it up it takes ages for it to sit idleing fine. if i sat there for it to warm up id be there for hours so i ride it cautiusly until it warms up, it takes a good few miles for it to idle around the 1100rpm mark.
is this normal on carbed bikes?
PostPosted: 07:12 - 25 Jul 2008    Post subject: Reply with quote
It's better for the bike to just start it and ride off anyway. A bike doesn't get properly warm idling.
Aren't you using the choke? Some bikes need it more than others.
TheDonUK
PostPosted: 07:22 - 25 Jul 2008    Post subject: Reply with quote
My old bandit 600 dident take very long to get warm, Often dident need choke to start it.
1100rpm sounds a bit low, could your idle speed be set to low? i seem to remember around 2k, but i could be wrong. As Ham says, start it up, ride off and take it easy for the first 5-10 mins, gradually decreasing the amount (if any) of choke you are using.
boredatwork
PostPosted: 09:18 - 25 Jul 2008    Post subject: Reply with quote
yeah i tend to agree, if mine idles around 1k its lumpy and prone to stall. i have mine around 1.5 closer to 2 and its ok. unless its something (else!) wrong with my bike...
DAS/Test: Passed March 08!
Bikes: CG 125 and k4 750 gsx-r
lee8040
PostPosted: 09:58 - 25 Jul 2008    Post subject: Reply with quote
ill up the idle
i do ride striaght off, but it trys to die at the lights so i have to use choke until it warms up
MaybeGuy
PostPosted: 10:23 - 25 Jul 2008    Post subject: Reply with quote
1100rpm??
that sounds about right, if not high to me!
i've got the SRAD idling at about 8-900rpm with no problems.
PostPosted: 10:49 - 25 Jul 2008    Post subject: Reply with quote
Use the choke then, that's what it's there for. Wink
PostPosted: 10:53 - 25 Jul 2008    Post subject: Reply with quote
Owners handbook for the Bandit says to have the idle set to 1100~1300 rpm. So it is on the low side of OK.
Tended to find the Bandits warm up pretty quickly. When standard my 1200 would need the choke to start but would stall at the first proper junction from my house if the choke was still on (~300 yards).
boredatwork
PostPosted: 12:17 - 25 Jul 2008    Post subject: Reply with quote
sorry for the thread hijack...but
does that mean there is something wrong with my bike? or just an anomaly?
Aikman666
PostPosted: 12:51 - 25 Jul 2008    Post subject: Reply with quote
I began typing this but I have a strange incling that bandits could be air cooled. But im not a big fan so I wouldent know.
IF it IS water cooled, make sure that your thermo hasnt jammed open, this would mean your cooling system was running full pelt constantly stopping it from warming properly Thumbs Up
Will work for petrol
My Design Blog
PostPosted: 12:53 - 25 Jul 2008    Post subject: Reply with quote
Not really. Probably something minor. Could well be something simple like the carbs needing balancing, or valves adjusting.
The Bandit is oil / air cooled.
Aikman666
PostPosted: 13:05 - 25 Jul 2008    Post subject: Reply with quote
Thanks Keith, knew I was probably barking up the wrong tree there Embarassed
My Design Blog
boredatwork
PostPosted: 13:24 - 25 Jul 2008    Post subject: Reply with quote
thanks keith - although our definitons of something simple vary wildly!
i need to give it a good general service - im toying with doing the valves as part of this (ive done it on my cg..)
balancing carbs i think i'll leave to a proffessional!
PostPosted: 14:12 - 25 Jul 2008    Post subject: Reply with quote
If you have vacuum gauges then balancing the carbs is a doddle. Far easier and quicker than doing the valves.
PostPosted: 15:01 - 25 Jul 2008    Post subject: Reply with quote
the 650 lump is water cooled, the older 600's are oil cooled. Thumbs Up
Dom_
Points Mean Prizes
PostPosted: 15:24 - 25 Jul 2008    Post subject: Reply with quote
I never bothered warming my 400, started it, put lid and gloves on. Off i go, straight to the redline. Didnt have any problems. Probably not advisable though.
boredatwork
PostPosted: 20:29 - 25 Jul 2008    Post subject: Reply with quote
i dont, but i guess they arent expensive...i dunno sometimes its the thought of doing stuff that scares me more than the actual doing, but chatting on here often gives me confidence so you never know i'll prob do a thread about it in a month!
ta
The last post was made 18 years, 94 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 96.8 Kb
