| D O G |
 D O G World Chat Champion
| mattgirv |
 mattgirv Trackday Trickster
 Posted: 07:44 - 27 Jul 2008 Post subject: |
I wouldn't worry about the seals if you are rebuilding the caliper. Don't bother reusing them or you'll end up redoing it all again in a few months time. You can get seals for damn pennies.
As for getting the pistons out without air/pressure through the caliper, try clamping the caliper and using tyre levers hooked into the piston to pry them out. I used this method on a 2-pot caliper and only took me about 5 minutes.
I managed to do it fine without damaging the caliper or pistons. You can pick tyre levers up for a couple of quid in Halfords.
Oh and you could just take the piston seals off and then try using some sort of penetrating fluid? Just make sure you get it all off afterwards. You'll get it apart eventually and then you can just clean it properly anyway. ____________________ Bikes: 1998 Honda VFR800Fi, 26,500 miles
1989 Honda CB-1, 38,000 miles |
| Kickstart |
 Kickstart The Oracle
 Posted: 09:35 - 27 Jul 2008 Post subject: |
Seals are not pennies (and the seal between the caliper halves is not available from Yamaha). Probably at least £20 a caliper for original ones. And for those with Brembo calipers you will probably find replacement seals are not available.
Air line is best, but I would say to pump the pistons out as far as you can with the hydraulics before splitting the caliper. Should leave the pistons barely held in place.
You can then use some pliers with something around them to protect the pistons, but you stand a good chance of wrecking the pistons if you do this and they are at all stuck.
| mattgirv |
 Posted: 09:56 - 27 Jul 2008 Post subject: |
Yeah pennies was probably an underestimation. I paid £4 for a pair of seals and dust seals for my Nissin 2-pot caliper. Though not replacing them can be much more costly, my point was it was well worth doing if you are bothering to service your brakes. ____________________ Bikes: 1998 Honda VFR800Fi, 26,500 miles
| D O G |
| Kickstart |
| iooi |
 iooi Super Spammer
 Posted: 13:38 - 27 Jul 2008 Post subject: |
Wemoto
£7.05 for a set of seals ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Kickstart |
| D O G |
The last post was made 18 years, 17 days ago. Instead of replying here, would creating a new thread be more useful? |
