What to buy? Maintenance of a new bike.
Deus
PostPosted: 15:52 - 26 Jul 2008    Post subject: What to buy? Maintenance of a new bike. Reply with quote
I've bought a rather expensive bike, so I figure I might as well throw in a little bit of extra money to make sure I take good care of it.
I was hoping someone could point me in the direction of a guide or something so that I can make sure I have all the basics to make sure I have everything I need to clean and keep the bike in top condition.
If I go down, so be it, but I want to make sure it is always in the best possible condition when I ride it Smile.
PostPosted: 16:15 - 26 Jul 2008    Post subject: Reply with quote
Chain lube, that's all you need worry about.
And stuff to wash it with obviously. Auto Gym stuff is good.
Deus
PostPosted: 16:19 - 26 Jul 2008    Post subject: Reply with quote
How big is the market for chain lube? I would assume different brands boast their products, any particularly famous/well known ones? Cheers.
Also, what about actually cleaning the bike (bugs, etc)?
PostPosted: 16:36 - 26 Jul 2008    Post subject: Reply with quote
I just use this Auto glym car stuff, works for me.
Yeah, the market is pretty big, I personally like Wurth HP Dry chain lube, or Mottrax HP lube, steer clear of PJ-1 chain lube IMO.
boredatwork
PostPosted: 18:49 - 26 Jul 2008    Post subject: Reply with quote
+1 Thumbs Up
DAS/Test: Passed March 08!
Bikes: CG 125 and k4 750 gsx-r
Spit-Fire
PostPosted: 09:17 - 27 Jul 2008    Post subject: Reply with quote
a set of tools would be a good idea to, every one will give you a diffrent answer for good chain lubes, just beacause you can only give advice on what you have used, auto sol for polishing you metals, muc off make good cleaning products(buy a multi pack, works out at better value), if your to lazy to scrub then a jet spray works well too(not to powerful mind, they strip grapics etc) and oil, erm cant think of any thing else, theres probably more tho
they say the good die young... i say we just live faster
Doddmaster
PostPosted: 09:49 - 27 Jul 2008    Post subject: Reply with quote
Get a decent 3/8" socket set, good ones normally come with torx, allen, and screwdriver bits too
map
Mr Calendar
PostPosted: 10:57 - 27 Jul 2008    Post subject: Reply with quote
Workshop manual - Clymer if you can afford, Haynes if you can or e-copy from the likes of eBay.
Learn to take off any panels/plastic. Remove as much as you can if you need to take your bike to garage for any work. Should reduce cost as much of this is labour/time in removing/fitting this stuff.
As for chain lube, chain adjust and low maintenance - get a shaft drive Wink Very Happy
syl
PostPosted: 11:14 - 27 Jul 2008    Post subject: Reply with quote
How much you got left over after the bike?
I'd suggest you spend money on:
Socket set
Screwdriver set
Torque wrench (probably need two to cover 8Nm to 200/300 Nm)
Breaker bar
Impact driver
Tool box/cupboard
If you're desperate to burn money the next step would probably be a compressor/Air tools/Welding kit
In that order.
Halfords pro do a good range and usually have one or two items on offer (like their 120 piece socket set at present). If you're loaded, look at Snap-On.
You'll also want a rear +/- front paddock stand.
Current bike: Kawasaki Z750S
Deus
PostPosted: 11:44 - 27 Jul 2008    Post subject: Reply with quote
Socket set
Screwdriver set
Breaker bar
Impact driver
Tool box/cupboard
In that order.
Cheers for the information. I'm in no way desperate to burn money, but I do want to be able to take good care of my bike.
I'll look into making sure I have most of the things on that list, although I think I'll pass on the compressor/air tools/welding kit for now as I don't think it's something that is financially a good idea at the moment Very Happy.
I'll have to find a Halfords near me and check out the deals. Thanks again, nice to have a "check list" of sorts Smile.
Spit-Fire
PostPosted: 14:16 - 27 Jul 2008    Post subject: Reply with quote
[quote]If you're loaded, look at Snap-On. [/quote lol Laughing loaded being the key word, there tools cost so much £££ its scary, buy what your going to use tools wise, no point spending money on tools that are beyond your maintenance abilities, the cleaning stuff depends on how furrow you want to be and as for lubes and oils buy it when you need it if your short for cash
Kal
PostPosted: 14:55 - 27 Jul 2008    Post subject: Reply with quote
One of the things that was suggested to me was buy as many inexpensive tools as possible - as they break get worn out replace them with more expensive ones as they are the ones you are getting the most use from. Thumbs Up
Kal...
Deus
lol Laughing loaded being the key word, there tools cost so much £££ its scary, buy what your going to use tools wise, no point spending money on tools t Laughing at are beyond your maintenance abilities, the cleaning stuff depends on how furrow you want to be and as for lubes and oils buy it when you need it if your short for cash
Not going to spent a fortune buying loads of tools that I won't use. However, Ill probably look into:
Socket set
Screwdriver set
Breaker bar
Impact driver
As they are the types of tools that can/will essentially last a life time. It's not like the world will suddenly stop using sockets or screwdrivers Smile.
However, not going to buy a professional mechanic set up either as that would be useless and I'm not a mechanic.
As far as lubes and stuff go, I'm thinking that investing a bit of money in some products to take care of the bike will save me money in the long run as I won't have to pay a garage for silly things like chain lubing and oil.
Kal
PostPosted: 15:05 - 27 Jul 2008    Post subject: Reply with quote
Pliers - needles and boxnose, wirestrippers and cutters, large adjustable spanner (you never know what size nut you need rounding off), tongue and groove adjustable plumbing pliers, medium sized hammer, metal drift (I use a spare axle I had lying around), Powerdrill, hacksaw.
A couple of pieces of wire attached to crocodile clips and an old bulb holder for testing when circuits are live.
Kal...
steppen22
PostPosted: 17:00 - 27 Jul 2008    Post subject: Reply with quote
Get the basic tools - you can actually get a wide range to start with in discount stores like poundland. Then if they prove unsatisfactory, go a little upmarket.
There's no point spending silly money on tools if all you want to do at first is remove a few panels, etc. Cheap tools will be up to such a task. Socket set, torque wrench, spanners, pliars, screwdrivers - nothing that any household should be without, really.
What you want is a self service routine.
First of all, set aside a few days just to take the non mechanical parts of the bike off/apart. Don't rush things. Label items - put any screws in a bowl, etc. If you do not make a deliberate effort to keep screws, etc, in order - something WILL go missing. Remove the fairing, the seat, etc, find the air filter, identify the spark, adjust the shocks, etc. Look at how you would remove the wheel, but don't do it, unless yopu very confident - becuase there are issues of balancing.
Basically, just take the bike apart, and then put it back together - in an orderly fashion and WITHOUT touching anything too important (ie. don't begin by disassembling the engine!). Think through everything you do - if I take this off, can I get it back on?
The point of this is to DEMYSTIFY your bike. To know where things are, what's hiding under what panel, etc.
- Clean the bike every two weeks - any products you're not sure of, TEST first. You might want: degreasers, chrome polish, shampoo, scratch restorers (although use cautiously), wheel cleaners, "back to blacks", plus chamois leather and microfiber cloths. You can spend a lot of money here, or you can experiment with "cheaper" products in stores like supersave, etc. It's up to you whether you want to buy "specialised" motorcycle cleaners but I've never been convinced it's necessary. Car cleaning gear should suffice.
Every month service the bike
check brake pads, oil level, idle setting, chain torsion, etc.
Every year either pay for the bike to be serviced or do it yourself
oil change, new pads, etc - consult your manual.
So, what do you need?
- tools. Basic for basic tasks, though. A screwdriver for a pound will undo a screw just as well as a 20 quid screwdriver.
- cleaning gear
- a decent weather cover
- puncture repair kit (relevant for your tyres)
- digital pressure guage
- Lubricants (chain oil, lithium grease for moving parts)
- engine oil (when needed)
- you might want to get spare brake pads, fluids, etc, in case of an emergency but it's probably not worth it until they;re needed
Remember, mechanical ptoblems require knowlegde. So get to the library and read up on things before you need to know.
But keeping the bike shiny is just a matter of bothering to, really.
no regrets, no retreat, no apology.
I've made mistakes in the past, and I apologise for FUCK ALL.
Deus
PostPosted: 17:17 - 27 Jul 2008    Post subject: Reply with quote
Cheers steppen22 for your input.
I'm planning on doing pretty much exactly what you said. Although I'm not a mechanic myself, I have been doing quite a lot of research into all of this as I think it is really important to know about something you are going to essentially trust with your life. Smile
And of course I've got a few mechanic friends to spare, just in case! My main goal is to avoid minor services (as you said, check brake pads, oil level, idle setting, chain torsion, etc) because it's not worth spending a small fortune for little things like that. Obviously I'll be getting the bike services properly by my garage when necessary.
And regarding your list of what I need, I think that's everything I now have on my list!
I've also obviously found (on the web) all the service and technical manuals for my bike. One of them has diagrams showing exact construction of every single component of the bike which is always useful to have.
Thanks again mate.
iooi
PostPosted: 05:02 - 28 Jul 2008    Post subject: Reply with quote
Now i have heard of Tyres' needing balancing but never the wheel when you have removed it.......
Where do i find a machine that will rebalance my wheels when i've thank them off.....
Other than that a good post, well apart from the clean every 2 weeks, just do it as needed. If you like a clean bike, or like me just like to ride and clean is a waste of time Wink
neil.
PostPosted: 06:21 - 28 Jul 2008    Post subject: Reply with quote
Just got the YBR its 4k mile service (in accordance with the manual), and the stuff they did was:
Arrow Oil change
Arrow Calliper service
Arrow Full chassis check
Arrow Checked/set valve clearances
Arrow Tyre pressures
Arrow Lubed pivot points
Arrow Adjusted the steering as bearings had a slight notch
Arrow Checked switch gear and bulb fitting as I had problems with a flickery front light which I sorted myself but they checked anyway.
The oil change and tyre pressure stuff I do myself also, but for the other stuff like valve clearances/steering bearings, I don't have the necessary skill for (yet!).
Big difference in the bike, it felt very different to start with and took a few miles of riding to get used to. The engine doesn't take so long to warm up before I need to turn off the choke, it climbs up to 40mph a lot more steadily than before. The brakes feel a lot sharper/less spongy and the clutch engages a little later than it used to, which makes gear shifting smoother. Worth getting done imo. Thumbs Up
As others said, generally you just need a few tools, lubes and cleaning stuff. I also spray anti-corrosion stuff on the exhaust/shiny bits as I noticed a bit of rust forming. Keeps it at bay. Oh and get a multimeter for checking electrics (voltages/continuity etc).
Moonie
PostPosted: 10:37 - 28 Jul 2008    Post subject: Reply with quote
The best polish I can recommend is Crystal Glo, which is wonder stuff, and if your feeling really flush, S100 cleaning spray for polished metal makes it look better than new when paintbrushed on and rinsed off. £12.50 a bottle though Shocked
Crystal Glo is £4 a bottle, can't go wrong.
neatbik
PostPosted: 20:09 - 28 Jul 2008    Post subject: Reply with quote
Autoglym super resin polish - its as good as anything out there, and definatly as good as more expensive stuff.
For shampoo i use Autoglym wash and wash, but any dedicated car/bike shampoo will do the trick.
Before i shampoo the bike i give the wheels and heavily soiled areas a spray of tfr, that shifts the heavy stuff.
After i've cleaned and chamoised the bike i give all the metal parts i.e frame, fork stanchions etc etc a wipe over with wd40/gt85 or whatever i havent run out off. This gives all the shiney parts a bit more protection against corrosion.
As for tools, Halfords Pro series are excellent, easily as good as MAC/Snap on, and cheaper too Thumbs Up
Get a Paddock stand too if your bike hasnt got a centre stand, makes lubing/adjusting the chain a lot easier Thumbs Up
Deus
PostPosted: 17:53 - 25 Aug 2008    Post subject: Reply with quote
Actually doing some buying now. Been looking at Halfords Pro stuff.
Spanner set? https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_216036_langId_-1_CarSelectorCatalogId__CarSelectorGroupId__varient__categoryId_76864_crumb_33958-31562-76859-76867_parentcategoryrn_76864
Seeing as it's half price, it's very tempting.. Thoughts?
Socket set? https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_177537_langId_-1_CarSelectorCatalogId__CarSelectorGroupId__varient__categoryId_76863_crumb_33958-31562-76859-76867_parentcategoryrn_76863
superstacker
PostPosted: 18:08 - 25 Aug 2008    Post subject: Reply with quote
If you want to buy Halfords Pro tools, find a friend that qualifies or has a trade card...
you get quite a discount Thumbs Up
Fnatic
PostPosted: 19:32 - 25 Aug 2008    Post subject: Reply with quote
Lidl were just selling a socket set and loads of other bits for £15 and a spanner set for £15.
Also a heat gun for £5.
Bikerchic1467
PostPosted: 20:57 - 25 Aug 2008    Post subject: Reply with quote
For washing and cleaning "Muck off" Spray it over the bike let it soak for a few minutes and hose off. I was amazed at how much dirt it takes off even the wheels. Laughing
PostPosted: 21:18 - 25 Aug 2008    Post subject: Reply with quote
Can't believe noone has mentioned corrosion inhibitors.
Scotoil F365 or ACF50 sprays applied to the bits you can't reach to clean effectively and used everywhere through the winter will make your bike last for much longer.
The last post was made 18 years, 21 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 138.07 Kb
