tyre bead seal
theweemonkey
PostPosted: 20:11 - 27 Jul 2008    Post subject: tyre bead seal Reply with quote
how do you seal the bead
have tried everything
tutton
PostPosted: 20:13 - 27 Jul 2008    Post subject: Reply with quote
Dont you need like the grease shit its like blue or thats what i think they use in our work, or maybe thats just to pop the bead on the rim. ill see if i can find out some more, ha
Ichy
PostPosted: 20:19 - 27 Jul 2008    Post subject: Reply with quote
Confused must be the heat.
Anyway, how you trying to inflate it? With smaller compressors I find it better to sit on the tyre, forces the rubber into the wheel.
theweemonkey
PostPosted: 20:47 - 27 Jul 2008    Post subject: Reply with quote
was trying to pump it with a footpump but dont think its any good think i need to go to a petrol garage and use there compressor
sanchezz_182
PostPosted: 20:49 - 27 Jul 2008    Post subject: Reply with quote
It does help to have some kinda lube on the rim, iv even used engine oil before Laughing Also with some tyres you need alot of pressure 50psi+
no sig, thats gay!!
tutton
PostPosted: 20:50 - 27 Jul 2008    Post subject: Reply with quote
NUR NUR.
im right see.
Ichy
PostPosted: 20:56 - 27 Jul 2008    Post subject: Reply with quote
Tutton, its a well know fact that schanchezz doesn't have a clue. So nur nur back doubled.
OP you need volume of air, not pressure, to bead a tyre, just take it to quickfit and ask them to blow it up.
doggone
PostPosted: 21:07 - 27 Jul 2008    Post subject: Reply with quote
WD40 will help it seal.
There are things you can try if high volume airline isn't available.
If you have a ratchet strap put it round the circumference thus pressing the tyre onto the rim.
A more spectacular one is a squirt of lighter fuel inside the tyre.
Ignite and the small explosion will pop it into place no wurries.
(this does really work but is a last resort I'd say .. Laughing )
Ichy
PostPosted: 21:43 - 27 Jul 2008    Post subject: Reply with quote
Not in the UK.
Ariel Badger
PostPosted: 21:46 - 27 Jul 2008    Post subject: Reply with quote
Ichy wrote:
Not in the UK.
Are the laws of thermodynamics different in the UK like riding on the left?
Gazdaman
I did a trackday!!!
PostPosted: 21:47 - 27 Jul 2008    Post subject: Reply with quote
You need a crap load of pressure very quickly. Like with a proper compressor.
You need to take the core of the valve out too, then give it a proper PSSHT and it'll pop on.
You'll really really struggle to do it with a footpump, and neither will a supermarket compressor.
Gaz
Ichy
PostPosted: 22:16 - 27 Jul 2008    Post subject: Reply with quote
H&S my friend. They will jump on you like a box of frogs.
ZRX61
Victor Meldrew
PostPosted: 00:28 - 28 Jul 2008    Post subject: Reply with quote
*snigger*...
theweemonkey
PostPosted: 17:28 - 28 Jul 2008    Post subject: Reply with quote
got the tyre all sorted. Very Happy
just added some soapy water added it a bottle took it the garage sprayed the tyre, pumped it up two little pops and bead was sealed
thanks for the advice. Thumbs Up
Cool
tutton
PostPosted: 18:11 - 28 Jul 2008    Post subject: Reply with quote
2 more people on the tutton is right-o-bus!
Finglonga
PostPosted: 19:06 - 28 Jul 2008    Post subject: Reply with quote
Cool
How high did you go with the pressure? To seat a tyre properly you will need at least 50psi in most cases. Took 80+ on my ZRX just to get the bead level. Don't forget to let the pressure out after to operating psi.
Andy Sez....
F.Y.Y.F.F.
The last post was made 17 years, 219 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 90.73 Kb
