rear wheel spindle
Eddie Hitler
PostPosted: 13:26 - 28 Jul 2008    Post subject: rear wheel spindle Reply with quote
Whats the best grease to use? I heard a water based is the best, but having a quick look in the local car shop they dont seem to have any.
Is multi purpose grease fine?
boredatwork
PostPosted: 14:17 - 28 Jul 2008    Post subject: Reply with quote
i would double check this just in case, but i used castrol lm grease i got from halfords. wasnt hugely expensive and seems ok so...
but wait till someone co-signs this as i dont want to be responsible for seizing up your expensive back wheel!
DAS/Test: Passed March 08!
Bikes: CG 125 and k4 750 gsx-r
PostPosted: 14:34 - 28 Jul 2008    Post subject: Reply with quote
Any lithium based grease should be fine for the bearings and the axle. Thumbs Up
Wouldn't go for water based greases (Confused). You want lithium based grease or moly based grease cos they're nice and water resistant.
boredatwork
PostPosted: 14:42 - 28 Jul 2008    Post subject: Reply with quote
phew.
i think the castrol one i have is lithium based.
relaxes.
PostPosted: 14:50 - 28 Jul 2008    Post subject: Reply with quote
Yeah that Castrol LM stuff is Lithium based. I've got a tub kicking around somewhere it's good stuff. Thumbs Up
Eddie Hitler
PostPosted: 14:51 - 28 Jul 2008    Post subject: Reply with quote
Ok cheers Thumbs Up Not sure where i heard water based greases from, but they did have lithium. Cheers!
PostPosted: 14:54 - 28 Jul 2008    Post subject: Reply with quote
Castrol LM should be plenty good enough. If you need it to be tougher then get yourself along to a boat yard and they'll sell tubs of grease intended for use in the propeller(s) and other parts which are underwater all the time.
Cigaro
PostPosted: 18:29 - 28 Jul 2008    Post subject: Reply with quote
I always use copper grease personally, not sure if that's bad or not?
PostPosted: 18:56 - 28 Jul 2008    Post subject: Reply with quote
Copper grease is to stop things seizing, put it on threads so that in a years time or longer you'll still be able to undo the bolt or on the back of brake pads to help prevent them making noise.
Copper grease is abrasive so not great for using to lubricate moving parts as over time it can cause wear. Don't think that it's abrasive enough to cause significant effects (or even noticeable until you start looking over a number of years) but IMO if you don't use it for lubricating moving parts then it can never be a problem.
The last post was made 17 years, 347 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 59.16 Kb
