EXTREMELY F**KED OFF :@ !!!!
SpeedfightBoi
PostPosted: 21:48 - 30 Jul 2008    Post subject: EXTREMELY F**KED OFF :@ !!!! Reply with quote
Hiya
Okay, as some of you may know, I have been having trouble with my ped....
I went out on it today with a couple of friends and it ran fine all the way
However i got back to my mates n decided on taking the spark-plug out to see how it is (As suggested by a fellow forum member)
Came out easily - Was a crispy brown colour...Put it back in
The Bastad went Cock-eyed, went in at an angle and i have knackered the threads up on my cylinder head up :@ Extremely pissed off!!!
Me, 2 of my friends and my friends dad tried tirelessly to get it in dead centre - all failed
However i was at it for 30 minutes and finally got it in, It required a full 5 minutes tightening up, and still was not fully on, the cap/cover thing wud not fully go over the sparkplug, but i tried my best.
I had 4 mile to ride home with it backfiring like mad up to 20mph then it was ok, bit spluttery though
So what do i do now? Can i get it re-threaded or do i need a new cylinder head?
Any help appreciated guys (Y)
07 speedfight 49cc btw
PostPosted: 21:50 - 30 Jul 2008    Post subject: Reply with quote
You've cross-threaded the plug. You can get it helicoiled no problem.
PostPosted: 21:55 - 30 Jul 2008    Post subject: Reply with quote
You can helicoil spark plug and it should be fine. From reading about it cos I'm needing to do it to my dead XR250 thats sitting in the garage, if you can then you're best off getting a head from a breakers or off eBay as the helicoil will always be a weak point.
If you can find a head cheaply then I'd say go for that, otherwise fit a heli coil and it should be alright. Thumbs Up
sickpup
Old Timer
PostPosted: 22:20 - 30 Jul 2008    Post subject: Reply with quote
Should be stronger than the original as its made of steel and the threaded area in the head will be larger spreading the load.
Oh and use a time-sert not a helicoil or you could get gas leakage.
veeeffarr
PostPosted: 22:28 - 30 Jul 2008    Post subject: Reply with quote
Hasn't your name just changed? :S
Sure you were just called Kizza...
SpeedfightBoi
PostPosted: 22:35 - 30 Jul 2008    Post subject: Reply with quote
No m8 :S :S Laughing
PostPosted: 22:37 - 30 Jul 2008    Post subject: Reply with quote
Or you might be able to save the thread. You can get sparkplug thread chasers that you screw in a bit like a tap.
Still need to get it started off square though and i'm not sure where you'd get one.
You might also get a second hand cylinder head off ebay. Going rate seems to be £15-20. Probably cheaper than having yours helicoiled.
veeeffarr
PostPosted: 23:17 - 30 Jul 2008    Post subject: Reply with quote
Er, that was weird, you were definately called 'Kizza' a second ago in this thread...I'm calling hacks!
ZRX61
Victor Meldrew
PostPosted: 00:01 - 31 Jul 2008    Post subject: Reply with quote
Just pop the head off & start from the other side Wink
PostPosted: 04:23 - 31 Jul 2008    Post subject: Reply with quote
Yep, I've done that before. Got a long-reach plug and ground a couple of flutes in it and screwed it in from below.
SpeedfightBoi
PostPosted: 12:43 - 31 Jul 2008    Post subject: Reply with quote
So i havent done anything so stupid that others havent done before?
Where can i get on of these helicoils from?? and how much ?
Cheers for all the help
Im-a-Ridah
PostPosted: 15:07 - 31 Jul 2008    Post subject: Reply with quote
Your probably best getting an engineer to helicoil it for you if you want it helicoiled, you can buy a helicoil kit but helicoiling is harder than putting a spark plug in.
Nufkamp
PostPosted: 15:14 - 31 Jul 2008    Post subject: Reply with quote
And the price of a helicoil kit will convince you to pay somebody who already has one to do the job for you Smile
As seen on Google Street View https://tinyurl.com/yfdvojc
Stalk
PostPosted: 17:39 - 31 Jul 2008    Post subject: Reply with quote
Speedflightboi, where are you. I am in Northampton and I have a sparkplug chaser that you are welcome to try.
Cheers,
Stalk
stirlinggaz
PostPosted: 18:47 - 31 Jul 2008    Post subject: Reply with quote
hi,
i have also done this,cheap alloy on the aprilia i reckon (thats my excuse)
i just got another head cover, 2nd hand off ebay, was only about £7 delivered.
couldnt be arsed with heli-coils or anything else i could make an arse of, lol
cheers,
GAZ
The last post was made 17 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 85.71 Kb
