Rear brake trouble
PostPosted: 08:37 - 31 Jul 2008    Post subject: Rear brake trouble Reply with quote
I'm sure I read a thread like this a while ago but I can't find it. The rear brake on TDM went FUBAR today. There was suddenly no pressure on the lever when I pumped it I got pressure back then as I rode away and tried to use it again no pressure. The bike is going in for a service saturday hopefully it should sort it. But I am a little worried. The brake disc was boiling went I went to touch it so much so that when I licked my finger and trouched it it made a hissing noise! There is still plenty of meat on the pads.
Any ideas?
Bezzer
PostPosted: 09:37 - 31 Jul 2008    Post subject: Reply with quote
If you haven't got a fluid leak then sounds like the master cylinder seal has gone, fluid goes past it so you're not getting much pressre. Pumping it eventually moves the pads in but they stick on as the cylinder won't draw them back that's why you have the boiling disc. If it's going in anyway let them know beforehand what's happening in case they need to get a master cylinder service kit in to sort it.
skinny
PostPosted: 09:51 - 31 Jul 2008    Post subject: Reply with quote
Sounds like the calliper is seized. the master cylinder does not draw the piston back the rubbers do if the fluid is old the heat generated will course the it to have no pressure.
oops I did it again....
PostPosted: 09:56 - 31 Jul 2008    Post subject: Reply with quote
I'll take it to peices and give it a clean, I relly hope this aint gonna cost alot, the service is gonna cost me £450 (inc rear tire) Shocked
skinny
PostPosted: 10:07 - 31 Jul 2008    Post subject: Reply with quote
Give the calliper and pad sliders a good clean up and copper slip and force the pistons in then pump them back out do this a few times don't push them in as far as they will go or you can end up damaging the rubbers, Just enough to get them moving nice.
Gazdaman
I did a trackday!!!
PostPosted: 10:24 - 31 Jul 2008    Post subject: Reply with quote
I'd say the heat is causing the lack of pressure.
The caliper pistons are crusty meaning they don't withdraw properly into the caliper meaning they stick onto the disk.
Causing a crap load of heat, which evaporates and water in the brake fluid. Which turns into gas which compresses easier than brake fluid leading to the sponginess.
OR the caliper seals could be shot as mentioned above.
Either way it's a fairly easy fix. Either it just needs a simple caliper overhaul (whip it off, clean up the pistons with a rag/cotton buds with brake fluid on, push the pistons back in and bleed it good.)
If the seals are knackered you'll have to remove the caliper, force the pistons all the way out, get the seals out, push new ones in, wet them with brake fluid, force the pistons back in (difficult, will need a G clamp or be careful with a vice). Then reconnect the caliper and bleed.
They'll probably do the former in a service but not the latter. A caliper seal kit will set you back about £20.
Gaz
Bezzer
PostPosted: 10:39 - 31 Jul 2008    Post subject: Reply with quote
err what?? rubbers draw them back Confused ?? you've got piston seals in the caliper and dust seals on the outer part neither of them draw the piston back. Piston seals just seal the pistons in the bore the dust seals you can even do without if you're feeling lucky. It's the fluid in the lines being drawn back into the master cylinder when you release pedal pressure that draws/sucks the caliper pistons back.
skinny
PostPosted: 10:47 - 31 Jul 2008    Post subject: Reply with quote
news to me not what I trained and at years ago or have worked with for years Rolling Eyes never mind You can take his advise or mine. But I think you will find I'm right on it being seized and over heating. It will cost you nothing to find out Laughing
Gazdaman
I did a trackday!!!
PostPosted: 11:51 - 31 Jul 2008    Post subject: Reply with quote
It's the vacuum effect of the fluid moving that draw the pistons back. The seals simply allow that vacuum effect to happen by keeping it sealed from the air.
The dust seals stop crap getting in there and messing up the seals.
Gaz
sickpup
Old Timer
PostPosted: 12:55 - 31 Jul 2008    Post subject: Reply with quote
Try again.
Piston seals are square section for a reason. Reason is they deform sideways and pull the piston back off of the pads. They are able to deform as the seal space in the caliper is slightly oversize.
If there was no need for them to deform you could just use 'o' rings.
skinny
PostPosted: 12:58 - 31 Jul 2008    Post subject: Reply with quote
Thankyou nice to know someone know what they are talking about.
PostPosted: 19:45 - 31 Jul 2008    Post subject: Reply with quote
Right I have taken them apart and cleaned them out and changed the pads. the pads where fairly new sub 3k miles and the piston was moderatly clean. I went down the road on the bike to post a letter and test them out. The brakes work fine (they did on the way home from work too) After getting back from my 1 minute ride I went to touch the rear disc but didn't I when my finger was about an inch from it I could tell that touching it was a bad idea, it was fucking hot! Does this mean a caliper rebuilt? the bike is easy to push and I cant here the brakes dragging at all. How much would this cost me from the dealers? I'm taking it in anyway so I might ask them to do it, depending on the cost.
sickpup
Old Timer
PostPosted: 20:09 - 31 Jul 2008    Post subject: Reply with quote
Did you take the seals out and clean behind them?
PostPosted: 09:28 - 01 Aug 2008    Post subject: Reply with quote
No just pumped the piston out til there was about 1cm of clean metal I will have a look tonight can I just pull them out without need to bleed the brake?
PostPosted: 09:52 - 01 Aug 2008    Post subject: Reply with quote
No, if you pop the pistons out and clean them and the caliper up properly you will need to bleed the brakes.
PostPosted: 10:47 - 01 Aug 2008    Post subject: Reply with quote
I'll get them to do it at the service then, I have never manged to successfully bleed brakes well.
I friend of mine as a bleed kit for his car which uses the spare tire to do it, I was thinking about setting something up for this on my bike I would need spare reservoirs caps and that is it.
PostPosted: 10:54 - 01 Aug 2008    Post subject: Reply with quote
Seen them (and got one). Remember that it uses a very low pressure (if you connect it to a fully inflated tyre then expect fluid everywhere).
PostPosted: 11:03 - 01 Aug 2008    Post subject: Reply with quote
Yeah I think he lets his down to about 15/20 psi are there any simple ways to do it? the old spanner bottle of fluid and tube methods still prove to taxing for me.
PostPosted: 11:14 - 01 Aug 2008    Post subject: Reply with quote
Tend to find that any way you try, you need to finish off with the conventional way. The conventional way works fine once there is some fluid through the system. Where it seems to be a real problem is from empty.
Some people use a syringe to push fluid through the bleed nipple and up to the master cylinder.
The Mityvac vacuum pumps are useful.
Thom
PostPosted: 11:22 - 01 Aug 2008    Post subject: Reply with quote
back bleeding, this can even be done without removing the master cylinder cap as i've had to do it this way (although it takes alot longer!).
Simply assemble your brake system onto the bike, remove the master cylinder cap and undo the bleed nipple, now with a very large syringe full of brake fluid, attatched to a piece of tubing, connect the tube to the bleed nipple and force the fluid up into the master cylinder.
close your bleed nipple while the tubing is still attatched to stop any fluid escaping/air entering and finally add the cylinder cap back. now just pump the brake a few times until pressure develops.
Simple, ten minute job with no need for any fancy tools.
PostPosted: 12:40 - 01 Aug 2008    Post subject: Reply with quote
I did try this once I will have another go.
Cheers Guys.
Gazdaman
I did a trackday!!!
PostPosted: 12:54 - 01 Aug 2008    Post subject: Reply with quote
I use one of those one way valve bleeding things from Halfords. Always have. They work great. Very easy to use.
Gaz
The last post was made 17 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 121.84 Kb
