| deliriousthun... |
 deliriousthun... Spanner Monkey
 Posted: 20:55 - 01 Aug 2008 Post subject: Engine problem, please advise |
Got off my bike today, put it on the centre stand and noticed between a couple of the fins there was a liquid boiling and frothing out.. creating little plumes of steam.. It had been raining so I thought at first I had just knocked a drop of water into it when I put it on the centre stand.. but it continued to froth and boil away for at least a full minute..
So I checked the oil level and it has dropped quite significantly, from completely full to somewhere between halfway and three quarters.. Not sure how it could be an oil leak though, as I wouldn't expect it to boil at normal engine temperatures.. and it didn't feel any hotter than normal..
I have a sneaky supsicion it has something to do with dropping it the other day.. I've ridden it a couple of times since then and not had a problem with it.. but I do remember it making a horrible noise before I flicked the engine off..
What's the next step? Is this something I'm going to have to take it to a garage about? I hope not cause I can't afford to , totally broke just now
Thanks, ____________________ Tom |
 ---- World Chat Champion
 Posted: 22:37 - 01 Aug 2008 Post subject: |
What kind of bike is it?
Could be a gasket on it's way out.
As for oil being lower,some bike burn oil.
What kind of liquid was it frothing out? (touch it,does it feel like oil or water?smell it)
Could maybe comment more if you can give some more info... ____________________ DRZ-400sm |
| deliriousthun... |
 Posted: 23:09 - 01 Aug 2008 Post subject: |
sorry
it's an xj600n.. all I can say is that it didn't smell like petrol.. as it was boiling I wasn't too keen to stick my finger in it.. and it seems to have all boiled off..
as far as I could tell from the froth it was transparent.. but I think most things would appear transparent when frothing and boiling like that, not sure on that..
I mentioned the oil because I've been running the bike for a few months and the oil level hasn't decreased.. (and I've been doing trips of around 90 miles on a regular basis).. I only checked it vey recently, and somehow it decreased to the level it's at now over a few days of hardly being used..
Sorry for the lack of specific info in the first post, if you think of anything else, just ask..
EDIT: and if it helps, the liquid was leaking out of the fins very close to the top of the engine.. the top 2 fins in fact..
 Posted: 10:17 - 02 Aug 2008 Post subject: |
Seems strange that it would be coming from the top of the engine!
I just had a look at a pic of one on google and it looks like the top 2 fins are below the rocker cover,and above the cylinder head So (as far as i know) theres no where in that area for fluid to be leaking! which makes me think it would have been something you spilt on it.
When you checked the oil last time,was it when the bike was warm/hot or cold?
This could make the oil level differ.
Other than this,is the bike running fine still?
Take it out for a spin again and see if it will do it again.If it does (and froths liquid again)try to grab some of it ,if it's hot you dont have to use you hand. ____________________ DRZ-400sm |
| deliriousthun... |
 Posted: 10:58 - 02 Aug 2008 Post subject: |
https://i71.photobucket.com/albums/i126/deliriousthunder/engine.jpg
I know you already looked.. but I didn't see any harm in showing you specifically where it appeared to be coming from.. the 2 little bits circled in red.. but on the left side of the bike..
I always check the oil level when it's warm..
I'll take it for a ride later, got stuff to get done just now
Thanks for your help btw
coming your way ____________________ Tom |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 11:00 - 02 Aug 2008 Post subject: |
i wouldnt worry. chances are a load of water rolled off the tank and just collected there.
only worry if it does it on a fully dry day. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Cigaro |
 Cigaro World Chat Champion
| deliriousthun... |
 Posted: 14:44 - 02 Aug 2008 Post subject: |
Ok.. I'll just ignore it, ride anyway, and keep an eye on the oil level.. and those little slots where it was frothing..
Thanks much for your help guys  ____________________ Tom |
The last post was made 17 years, 342 days ago. Instead of replying here, would creating a new thread be more useful? |
