Fueling troubles.
Thom
PostPosted: 13:35 - 02 Aug 2008    Post subject: Fueling troubles. Reply with quote
To start the bike in wuestion is a suzuki gs500e from 1990.
I have recently installed new carbs and have had them working perfectly allowing me to attempt an mot of which i failed.
Now that these failures are fixed i need to get the bike to run, and i can, until the bikes begginignt o warm up when it appears the right hand cylinder stops getting fuel.
Now luckily i have a spare carb which i can fit but im wondering what else could be the problem?
I've cleaned the carb and obviously it works but after a while it begins to bog when revved and then wont start after, however spraying easy start into the carb lets it run for a short while.
Any suggestions?
If it means anything the rhs cylinder is getting much hotter than the left, i also have a spark in both cylinders and fuel to the float bowls. the carbs are balanced too.
Edit: i've had it start on the choke a couple of times after this stalling/bogging although it wont come off the choke without stalling.
The last post was made 17 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.87 - MySQL Queries: 13 - Page Size: 28.3 Kb
