2 Stroke Question?
Jenks
PostPosted: 13:38 - 04 Aug 2008    Post subject: 2 Stroke Question? Reply with quote
Hey all, Im quite new to the world of 2 strokes -so this might seem abit stupid!
Basically. i have a 1978 MZ TS 250... - Runs on Premix 2t.
Now when i first got it, it smoked like a crack whore...
Now since i emptied the fuel and put a fresh load in with the correct mix, it really hardly seems to smoke. In fact ive videoed my friend on it down the road, and there is no smoke at all..
Is this bad? Good? I thought they were 2 smokes for a reason??
Any help would be brilliant!!!
1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi
Ant132
PostPosted: 14:24 - 04 Aug 2008    Post subject: Reply with quote
Mine runs on an oil pump at the correct ratio. In the morning it smokes a fair bit, and will continue to smoke for the first 10-20 seconds of riding after a full warm up, then throughout the rest of the day there will be no smoke at all.
If you're worried about it, it might be worth increasing the ratio of 2-stroke oil just for peace of mind. They all smoke, so being able to see some just for your own benefit would be better than having none at all. Always good to have a bit too much than not enough Thumbs Up
Ant
1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200
mca6969
PostPosted: 14:29 - 04 Aug 2008    Post subject: Reply with quote
yeh when i first start my engine it smokes like a bitch but as it warms up i dnt think i can see it sooo Smile
Yamaha Aerox 07 Rossi rep De restricted variator + polini belt
Frost
PostPosted: 16:57 - 04 Aug 2008    Post subject: Reply with quote
when warm its normally best to check for smoke with your nose Wink
tutton
PostPosted: 21:13 - 05 Aug 2008    Post subject: Reply with quote
My 50 dosnt smoke at all really, 8 months and hasnt seized yet Wink
PostPosted: 21:20 - 05 Aug 2008    Post subject: Reply with quote
My scooter leaves a nice cloud as I set off but once I'm at the end of my road (about 150 metres) it's stopped.
My dad's scooter is the same as mine, smokes a bit then disappears at the end of the road.
My RX-S smokes until it's warmed up then it's smokeless. Used to smoke a shed load until I adjusted my oil pump.
My dad's RD 250 smokes a little bit and on full throttle smokes a fair bit (It looks cool as it comes out in a twirl and smells nice Laughing) yet his oil seems to last him ages.
I wouldn't worry if it's not smoking but if you are just increase the premix ratio.
petemell
PostPosted: 22:36 - 05 Aug 2008    Post subject: Reply with quote
Too much oil can cause the bike to run lean, as more oil means less petrol in the mixture.
It may be ok but it could make the engine run hotter using extra 2t oil.
cal91
PostPosted: 22:56 - 05 Aug 2008    Post subject: Reply with quote
i belive it might be to do with the ratio before being incorrect. Maybe to much oil.
But mine is the same, smokes more than a old double decker bus when cold but after 30 secs its usally clear.
It might be to do with the engine warming the gases after 30secs so they are clear.
I wouldnt be too bothered about it tbh. As long as the its the correct ratio to whats on the oil bottle it should be fine.
We are the Patriots! Love your country.
Jenks
PostPosted: 06:41 - 06 Aug 2008    Post subject: Reply with quote
Awesome, Thanks!
Ill drop it out then and use another mix!
cal91
PostPosted: 20:00 - 06 Aug 2008    Post subject: Reply with quote
Jenks wrote:
Awesome, Thanks!
no, just use it i dont think it will do much harm. Just mix it properly next time Thumbs Up
PostPosted: 20:03 - 06 Aug 2008    Post subject: Reply with quote
cal91 wrote:
Jenks wrote:
Awesome, Thanks!
If he hadn't mixed it properly the engine would have seized from lack of oil.
cal91
PostPosted: 21:05 - 06 Aug 2008    Post subject: Reply with quote
[quote="ms51ves3
If he hadn't mixed it properly the engine would have seized from lack of oil.[/quote]
i think its more oil if there more smoke.
Gazdaman
I did a trackday!!!
PostPosted: 21:11 - 06 Aug 2008    Post subject: Reply with quote
If you've got the petrol to oil ratio correct it won't actually smoke all that much.
Too much oil = loads of smoke.
It normally smokes a bit when it's cold, and when accelerating hard.
My MZ barely smoked when it was on the oil pump. Smoked like hell when I ran premix as a race bike, but I suspect I cocked up the sums.
Gaz
Rockhopper
PostPosted: 19:42 - 08 Aug 2008    Post subject: Reply with quote
Too much oil also makes your mixture lean and you risk siezing it that was as well!
smegballs
PostPosted: 08:42 - 09 Aug 2008    Post subject: Reply with quote
My MZ ETZ250 hardly smokes at all when I use the correctly measured amount of oil and is warmed up. Usually tho i tend to approximate a bit rather than the using the measuring bottle so runs smokeyish but nothing like a proper screen.
I always mix a little bit overoiled than underoiled, altho over oiled can be just as bad as under oiled. This is because the oil displaces a similar volume of petrol. As the mixtur is sucked thru into the crankcases most of the oil drops out of suspension and onto the big-ends, mains etc as in normal 2t lubrication
As now there is a disproportionate amount of air to petrol now (too much air), hence running weak. Your engine will have a tendency to overheat and hole your piston.
Fun times abound for everyone.
Also what do other people think of the MZ oil pumps, mine has been converted to premix as apparently the MZ pumps have a reputation for failing hence its safer to have your oil in the tank.,
Hope this helps
Rich
Jenks
PostPosted: 10:44 - 09 Aug 2008    Post subject: Reply with quote
thanks Smile
Mines the TS so i dont have the oil pump!
Gazdaman
I did a trackday!!!
PostPosted: 11:23 - 09 Aug 2008    Post subject: Reply with quote
I used to trust my ETZ 251 oil pump implicitly.
Same with the ETZ 125. Never had a problem.
Gaz
smegballs
PostPosted: 13:41 - 09 Aug 2008    Post subject: Reply with quote
Is your TS the Supa5??
Apparently the Supa5 engine was more powerful and torquey than my ETZ 250 block.
I would be interested to see if a Supa5 block would find its way into my frame or whether the engine mounts are different
salty21
PostPosted: 14:08 - 09 Aug 2008    Post subject: Reply with quote
RockhopperPosted:
petemell wrote:
Don't forget if you increase the oil mixture as other members have recommended, you are theoretically running a mixture with less petrol and thus may make the bike run leaner and overheat.
So I would stay with the standard ratio to be on the safe side.
how does adding more oil make it run leaner Rolling Eyes.
a leaner running engine will have "less oil" or too much air in the mix. How can having too much oil make the bike overheat?? oil reduces friction, thus reduces heat.
if you dont know, dont post a guess, because that will just confuse and mislead folk,
from the wise words of the green wheelie bin,
"if in doubt leave it out"
69.9mph
PostPosted: 16:31 - 09 Aug 2008    Post subject: Re: 2 Stroke Question? Reply with quote
A modern synthetic two-stroke oil will produce far less smoke than an old (cheap) mineral oil that may have been in there before. As long as the mixture is correct don't worry about it.
69.9mph
PostPosted: 16:41 - 09 Aug 2008    Post subject: Reply with quote
This is a pre-mix, not direct injection, so in proportion, more oil = less fuel and in theory a leaner mix. However, we're not talking about a high performance engine here and I doubt that there would be much of a problem with some variation.
Quite. How about practising what you preach? Wink
salty21
PostPosted: 17:46 - 09 Aug 2008    Post subject: Reply with quote
one guy said more oil will make the engine overheat and the other said too much oil would seize the engine, im not saying im a mechanical god but i definately wouldn't say a mix with too much oil would do either of these.
so they have either been seriously mislead or just like to guess in the hope that they may look knowledgefull, as for "practice what you preach". the theoretically lean mix in which you speak of will cause no serious damage to the engine therefore was not in my interest to incorporate in my previous post.
Gazdaman
I did a trackday!!!
PostPosted: 19:49 - 09 Aug 2008    Post subject: Reply with quote
Salty21...
A lean mixture runs hotter. A piston will expand and heat seize. Therefore both overheating and seizing.
So please, if you don't know. Don't post.
Gaz
salty21
PostPosted: 19:54 - 09 Aug 2008    Post subject: Reply with quote
did you even read the posts wally Middle Finger if you did you would see that is what i am trying to say ffs
Gazdaman
I did a trackday!!!
PostPosted: 20:33 - 09 Aug 2008    Post subject: Reply with quote
That's the bit that bothered me most..
Gaz
The last post was made 18 years, 80 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 131.06 Kb
