GIve me the lowdown on.... observation!
steppen22
PostPosted: 14:46 - 04 Aug 2008    Post subject: GIve me the lowdown on.... observation! Reply with quote
I think my observation skills are quite high, because I'm a keen cyclist.
Still, there's always room for improvement. My problem is, I don't have an "obseravtion" routine - sometimes I look too early, other times I leave it too late. I tailer my observation to the road situation, which I think is fine, but on the test, it won't be appreciated.
So what's going to be expected of me during the test.
What does OSM/PSL actually break down to on the road?
Okay, I'm approaching a left turn. Am I right in thinking that this is the routine:
- Mirror check.
- Signal
- Move to left
- Slow down, switcfh gear
- look into road, behind, etc.
- take bend.
- look behind, accelarate
Where does the lifesaver come in?
Is it before I signal (with the mirror checks)
Or before I turn? Or both? Oh, my poor neck....
When should I begin the routine? 100 metres away? 10 metres?
When should I OSM/PSL?
When should I do lifesavers (seem unnecessary most of the time - the mirrors suffice)
Will I have to do the "head shuffle" - that annoyed me during my cbt, "look in my mirrors!? - I AM looking in my fucking mirrors!!" , how far away does the examiner ride? Is the test pretty much front tyre to my exhaust, so I have to be spotless for the entire time?
no regrets, no retreat, no apology.
I've made mistakes in the past, and I apologise for FUCK ALL.
deanoet
PostPosted: 15:48 - 04 Aug 2008    Post subject: Reply with quote
Mirrors
Look (shoulder check(s))
Signal
Manouevre
Shoulder Check before you turn
That is how i was taught
Always do a right shoulder check, so for turning left:
Check both mirrors starting with the right, check both shoulders starting with the right, signal to the left, position to the left, before you start the turn check over your left shoulder again to make sure nothing has come up your inside, make the turn
Same for turning right, only you dont need to do a left shoulder check
When speeding up or slowing down check both mirrors (after coming out of a junction / roundabout etc etc)
If there is a change of speed limit check both mirrors and both shoulders before slowly down / accelerating
Keep checking both mirrors every 30 seconds or so
OSM - Observe Signal Manouevre
PSL - Position Speed look (added onto OSM, Manouvre = position and speed)
MSPSL - Mirrors Signal Position Speed Look (car learners are taught this as they dont do shoulder checks)
POM - Prepare Observe Manouevre (for when moving off from stationary)
jack_zxr400
PostPosted: 15:57 - 04 Aug 2008    Post subject: Re: GIve me the lowdown on.... observation! Reply with quote
I'm not sure the exact distance but when you come up to the junction you begin your OSM/PSL
-Observation: check mirrors
-Signal: indicate your direction
(*life saver comes in here*)
-Manouver: moving into the correct road position for turning (if your not already in it).
-Position: when your actually in the correct position
-Speed: slow down
-Lifesaver: perform this before you make the turn
then straighten up your bike, check your mirrors and cancel indicators
hope it helps Wink
Previous Bike: ZXR 400
Current Bike: R6
Test Date: 8/8/2008-PASSED
steppen22
PostPosted: 16:47 - 04 Aug 2008    Post subject: Reply with quote
Is there a difference between a lifesaver and a shoulder check? I'm quessing not.
See, it all seems so involved, but it's just a matter of developing the "habit"!!
Im-a-Ridah
PostPosted: 16:56 - 04 Aug 2008    Post subject: Reply with quote
There's no need to do a right lifesaver when turning left, lifesavers check the blindspot you are about to cross... at what point during your left hand turn do you see yourself passing through your right blindspot?
For a left turn personally:
right mirror
left mirror
move to left of the lane
left lifesaver + left indicator
turn left
cancel indicator
check both mirrors
Paivi
PostPosted: 16:59 - 04 Aug 2008    Post subject: Reply with quote
Same thing. Basically, every time you change position, be it turn a corner or change lanes, you need to do a life saver to make sure the coast is clear.
It also acts as a warning to a knowledgeable car driver behind you that you're about to change your position.
In real life, life saver is more important than indicating, so never forget to do them; they're not called life savers for nothing.
Some people don't do them when turning left, thinking that there won't be anybody behind them anyway. Well, cyclists and other bikers might be there, and cyclists on a cycle lane have priority if they're going straight.
Before you know it, you'll be making life savers when walking... Embarassed
Im-a-Ridah
Shoulder check is looking backwards over our shoulder to see what is behind you e.g before you pull away.
A lifesaver is checking the blindspot that lies between your frontal area vision and what you can see in your mirrors, which is why you turn your head to the side!
deanoet
PostPosted: 17:00 - 04 Aug 2008    Post subject: Reply with quote
it seems to differ from different schools
I was taught to do a right life saver before signalling left, but other people havent and have passed okay..
I would be tempted to get a couple of hours with an instructor just to brush up
neil.
PostPosted: 17:01 - 04 Aug 2008    Post subject: Reply with quote
Haha yeah I noticed myself doing that.... Laughing
Noxious89123
PostPosted: 17:06 - 04 Aug 2008    Post subject: Reply with quote
There is a need, at the very least, on your test.
When your coming upto the bend, you will be looking to the left, around the bend. Just before th turn you will look over your left shoulder and then turn.
If you are looking left, there is the potential for a car to pass you, and then potentially move in front of you / cut you up / brake.
You need to do a mirror check and RH lifesaver before you change road position, or accelerate. You need to check mirrrors before braking. You need to do a lifesaver in the direction you are turning, as the very last thing before you actually start the turn.
Remember this though; Don't do so many lifesavers and mirror checks so that your forward observation suffers!
The last post was made 17 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 70.46 Kb
