Engine problem
Ge4orce
PostPosted: 16:57 - 06 Aug 2008    Post subject: Engine problem Reply with quote
Hey my Yamaha xtz 125 is giving me sleepless nights.The problem is something with the engine or the carburetor.I have took the bike to the yamaha dealer and the mechanic has fiddled with the jets and the carb settings but it still won't fix the problem.The bike pulls ok in 1st,2nd and 3rd but wheen you go into 4th and 5th and give it full throtlle or nearly full throttle it justs keeps on missing.It misses espescially on the low to midrange and after it stops to miss its has no top end power.The mechanic suggested that the piston rings may have been damaged.I just wanted to here if any of u guys might know what the problem is
Honda is the best
PostPosted: 17:06 - 06 Aug 2008    Post subject: Reply with quote
When you saying missing do you mean misfiring?
Ge4orce
PostPosted: 17:12 - 06 Aug 2008    Post subject: Reply with quote
Yeah sorry I mean misfiring.I don't actually speak English so I don't quite know all the terms in english
Honda is the best
PostPosted: 17:39 - 06 Aug 2008    Post subject: Reply with quote
Have you replaced the spark plug? If so, have you replaced the plug cap?
Ge4orce
PostPosted: 20:51 - 07 Aug 2008    Post subject: Reply with quote
Yes the spark plug has been changed.I don't think the plug cap has been replaced
Honda is the best
cestrian
PostPosted: 10:43 - 08 Aug 2008    Post subject: Reply with quote
So it's OK in 1st, 2nd and 3rd.....is that at full throttle in those gears?
Higher gear + full throttle = heavy load.
Heavy load + weak spark = possible misfire.
I suggest cleaning all the connections in the ignition system. Can't do any harm can it?
Ge4orce
PostPosted: 18:19 - 10 Aug 2008    Post subject: Reply with quote
Yes that is at full throttle in those gears.I will clean the ignition and replace the spark cap
Honda is the best
The last post was made 18 years, 98 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 50.92 Kb
