Rs doesn't feel right...
5v3d3b0
PostPosted: 01:51 - 08 Aug 2008    Post subject: Rs doesn't feel right... Reply with quote
I just finished the repair today. New bearings, completely new cylinder barrel and piston etc etc. 650 quid spent.
Basically I managed to start it which took some fooking effort. Then when I rode it it just felt weird. REALLY weird. The power is strange, and the handling feels weird too..
Question number 1: Could the engine be running a little weird cause it's hasn't been in use for 4 months and stuff needs to be circulated etc?
2: Could the handling be (if it isn't cause i'm not used to it) be because I've maybe set the engine slightly off centre?
3: How many miles breaking in should I do for a bottom and top end rebuild?
5v3d3b0
PostPosted: 12:35 - 08 Aug 2008    Post subject: Reply with quote
Sad
PostPosted: 12:43 - 08 Aug 2008    Post subject: Reply with quote
Nothing really to circulate. Coolant is pumped round, gearbox oil is pretty much where it needs to be, petrol goes direct to the car and without 2 stroke oil it would seize pretty rapidly. If the carb had been full of petrol when stored then it might be an issue, but not if stored empty.
The engine being slightly off centre wouldn't make a difference, but check the swinging arm spindle is tight and that the adjuster on the spindle is correct (used to get rid of the clearance between the swinging arm and frame).
Complete rebuild I would say to run in as though it was a new bike.
5v3d3b0
PostPosted: 15:38 - 08 Aug 2008    Post subject: Reply with quote
It sounds different too...Could that be because the cylinder is Mitaka?
skinny
PostPosted: 16:00 - 08 Aug 2008    Post subject: Reply with quote
Is it actully running badly or just different it could well be in your mind but I would double check any bolts you have undone for the handleing. with a new cylender I would hope it would feel a little different. Very Happy
oops I did it again....
5v3d3b0
PostPosted: 16:26 - 08 Aug 2008    Post subject: Reply with quote
The handling feels weird at the front rather than the back but i havent touched anything there. It's also pretty spluttery... Sounds like a tuned 50 which i dont like... I want to find someone with an rs i can compare to. Also how many miles running in would you do for a new bike?
steve32
PostPosted: 16:31 - 08 Aug 2008    Post subject: Reply with quote
when i did some repairs to mine and put the rear wheel back on it was out by 3mm and it made a big difference it was sending me into the otherside traffic, slight ajustment and it runs straight now
suzuki GSX 600F katana .: ~my bike up for sale~ :.
CBT = Completed
DAS= Working on it - theory test = Passed
5v3d3b0
PostPosted: 17:52 - 09 Aug 2008    Post subject: Reply with quote
I just went out for a little mountain ride to see what the bike feels like more in depth.
Felt like absolute crap.
So unstable in the corners, hardly any power, wobbly and awful. From 5750 rpm to 6250 rpm i couldn't make the leap if it was uphill. Only spluttering.
I stopped at a cafe for a fag, and checked the back wheel cause something was obviously wrong there. Checked the rear tyre. Like a bloody marshmallow it was!!
Front was pretty soft too.
Went back down to the city and to the first petrol station. On the rear tire I had a pressure lower than 1 Shocked Pumped the tires and rode off.
What a difference! First of all it felt like it was throwing me into the corners, almost scary after 20 minutes of shiteness. And it felt like the horsepower had been doubled! The tires had been so soft that the engine wasn't even strong enough to battle them properly. Even at the low rpms im riding now (absolute max 7k) the bike was way faster when the tires were pumped.
Talk about a rookie mistake Embarassed So happy that my bike isn't shit
The last post was made 18 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.48 - MySQL Queries: 13 - Page Size: 58.49 Kb
