Shit tyres, bike setup or me
bEN_
PostPosted: 22:21 - 08 Aug 2008    Post subject: Shit tyres, bike setup or me Reply with quote
This is really starting to piss me off now, had a decent week down here with the weather so i've been out as much as i can really.
After about 10-15 mins of cruising around i tend to build my speed up and start to have some fun, anyway when i go into a tight corner or roundabout and get a decent lean angle a few times i've felt the front tyre start to slide, i'm taking it as an early warning sign that if i push much harder i'll be on my arse but it's caught me out a few times and it's starting to knock my confidence, i can't understand whats causing it, i've only done a few basic things to check it's not obvious to me.
changed the tyre pressures to what i was used to from 33psi to 36psi
(what it recommends in the manual ) this changed nothing apart from making the front feel lighter going into corners.
checked both tyre sizes so the profiles weren't dodgy, 120F 180R
tyres have loads of life left, they are Dunslops 208RR's even though they shouldn't be the issue Wink
So then i thought it could be something i'm doing wrong, body position etc?
i might see if dropping the forks or adjusting the rear suspension helps, i don't feel it move when i sit on it because i weigh fuckall but i'll check properly tomoroww, any help appriciated it's doing my head in, i wish i was struggling for grip at the back, at least thats fun. Twisted Evil
2010 Ducati 848 Dark
Lamp Post Enthusiast
PostPosted: 22:32 - 08 Aug 2008    Post subject: Reply with quote
Maybe you're just trying to lean further than is necessary?
bEN_
PostPosted: 22:40 - 08 Aug 2008    Post subject: Reply with quote
I don't think it's that because i don't even try to get my knee down, i think it might be my body position more than anything, dug up a few old mags and from pictures i've seen it looks different to what i'm doing. i just suck atm Laughing
Fastkwak
PostPosted: 22:49 - 08 Aug 2008    Post subject: Reply with quote
Its the tyres mate they are shit i had em on my 12R and if i gave it some coming off a roundabout or out of a bend i was laying serious darkies to the point of looking good but staining my pants big time and the front never quite felt planted in the bends i binned em and went onto metzler sportecs and its a different bike altogether my mate had the same on his 04 ZX10R and loved the bike once he changed.
Dave Thumbs Up Mr. Green
Kiss my ASS im gone. current ZX12R previous ZZR1100,Gpz1100 uni,GT750,VT500,CX500
GT550,various Superdream 250&400,RD350LC,RD400DX,Ts250ER,DT175MX
CB125T superdream
PostPosted: 22:50 - 08 Aug 2008    Post subject: Reply with quote
Don't think about it too much. Balance the bike by pressing on the pegs, loose grip on the bars, keep your head up looking where you are going and repeat after me: "Smoooth, smooooth, smoooth.".
Try sticking your elbows out (helps me, no idea why).
If you are thinking about leaning the bike over, you're concentrating on the wrong thing and will keep looking at the ground next to you. Concentrate on looking where you are going and keeping the throttle action smooth, the corner will happen by itself.
Deckx
PostPosted: 06:01 - 09 Aug 2008    Post subject: Reply with quote
its not the tyres, i had a set of 208rr's on my zx6 and really liked them
The back always let go before the front but you still had a feeling of control.
Remember when i got the the bike first with the 208's, it felt a bit funny at the front but added more front pre-load, think i got about 6 lines showing as well as dropping down the forks 6-7 mm.
Sounds like your suspension needs sorting, go to Sportsrider.com, they have rough guides of settings for your particuliar bike.
Think 36psi is too high, i normally run my tires at track pressures 30/ 31 but i ride mostly on track..but when i ran with 34 + on the road it felt way too hard with zero grip.. could try 32 back and 33 front and see what that feels like...
MattEMulsion
PostPosted: 06:53 - 09 Aug 2008    Post subject: Re: Shit tyres, bike setup or me Reply with quote
You have quoted the width of the tyres, not the actual profiles. So what is the profile of the front tyre? It will either be a 60, a 65 or a 70. I am assuming that your bike is an R6, as in the picture.
If it is a 60 then this is highly likely to be your problem. R6's came with a 60 profile as standard but it is a very common mod to change this up to a 70 to get rid of the exact front end tucking under problem that you describe. Thumbs Up
Yamaha YZF-R6
mistergixer
PostPosted: 08:58 - 09 Aug 2008    Post subject: Reply with quote
If it's a new bike, and you're running the original Jap spec OE Dunlops, then yes, they are shit, and i would advise you to get shot of them.
Aftermarket European spec 208s are a great tyre - i always used them on my SRAD600, and now use qualifiers on my 750.
The 208s will slide gently prior to actually letting go, which i think is a good thing - i like a bit of warning, instead of just a sudden loss of grip.
I'd focus on your riding personally, it sounds like you might be trying too hard to lean too far - the resulting mental and physical tension can rob you of your control of the bike. Relax, take it easy, focus on being smooooooth - you'll probably find yourself going faster, i know i certainly do!
Space Monkey #7
Type_Mo
PostPosted: 11:27 - 09 Aug 2008    Post subject: Reply with quote
benn, change your dunflops for a set of conti road attacks! thats wot i did and never regretted it for a moment! Very Happy
Keir
PostPosted: 11:48 - 09 Aug 2008    Post subject: Reply with quote
have you fiddled with the suspension? switch back to the manufacturers standard setting if you have.
other than that my money would be on your riding style as you admin your not pushing it that hard so id be inclined to think your nowhere near the tyres limits.
Current : '08 Yamaha FZ1s
Reppyboyo
PostPosted: 13:44 - 09 Aug 2008    Post subject: Reply with quote
Tried increasing pre-load on your forks?
bEN_
PostPosted: 14:24 - 09 Aug 2008    Post subject: Reply with quote
Found a decent setup guide that might be able to start me off in the right direction, since i got the bike i've not fiddled with anything on it.
I need to get a picture of video of myself Laughing so i can see how badly my body position is, sometimes after riding for an hour or so i get back ache to, don't think it's because im 6ft but maybe i'm riding twisted in the corners or something, whatever it is it's bugging me.
the tyres seem ok apart from the front, on the rear you can run it to the very edge yet at the front there's quite large chicken strips Shocked
the front tyre is 120/70 i think which is about right, i'll also try lowering the pressures again, i guess it's a trial and error thing but i'm convinced it's how i'm riding that is the problem. Cool
neatbik
PostPosted: 18:14 - 09 Aug 2008    Post subject: Reply with quote
I reckon your gripping the bars too hard. As stinkwheel said, grip the bike with your legs on the tank and have a really loose grip on the bars. All you should be doing with the bars is steering the bike. Counter steer into the corner, then let the bars track round Thumbs Up
Scouse
PostPosted: 18:37 - 09 Aug 2008    Post subject: Reply with quote
Perhaps you've been hitting the chicken strips by leaning further than normal, obviously the strips will still be unscrubbed and slippy. You will have some strips on the front as a result of counter steering anyway.
R6's are known for this and I've felt it myself, adjusting the preload sorted it out quite well for me Thumbs Up
Oh and the back ache is another common one for early R6's seeing as they force quite a cramped position when riding.
The Tot
PostPosted: 19:06 - 09 Aug 2008    Post subject: Reply with quote
It's all psychological and all to easy to blame the tyres ... well I did. Getting new tyres acted like a placebo because it gives you that feeling of confidence and security.
Get some stomp grips. I had them on the bike for a week and i notice how much less of an effort i put in whilst hanging off the bike or under braking. I've done the same sections previously and used to come home with very bad calf aches form steering input and using peg weighting to hold a line. Certainly by allowing the outside leg to grip onto the tank, you're able to shift as much as your weight into the bed as possible.
I would try and explore your riding style. Find a clear section of road and keep doing it experimenting with different styles - applied countersteering + lean, hanging off, not using your brakes etc etc... Only you can solve your problems.
Getting your suspension back to stock will help... IIRC, R6's OEM tyres were 60 section at the front - 65 can be used as a compromise. You won't be able to reach the edge of the tyre on a 70 cos of the steeper profile, so you'd probably have to hang off more to keep the bike more upright.
Only one way to tell, and that's getting new rubber when yours wear down.
Tyre choice is all down to preference so try them all. My money's on the tyres - get something more appropriate for the road and you'll have easily the best investment for your riding. If you don't like dunlops and have a distinct prejudice for them, then people will be able to recommend other tyres - i'm happy with my Dunlop Qualifiers and Roadsmarts... I suggest you read this month's RIDE - it compares the differences of riding a CBR600F-S on dunlops roadsmarts and dunlops Qualifier RR (replacement tyre for the D208RR). Rider found that on the road, the sports touring roadsmarts held the heat better and had more wear towards the edge of the tyres. I've found that on my bike i've got NO chicken strips with the Roadsmarts (sports touring), whilst on the Qualifiers, it was a constant 3-5mm band on both sides.
Hope this helps. If you factor out all the other variables, chances are you'd find THAT niggling element of your riding/bike and address it.
Never argue with autism
binge
Emo Kiddy
PostPosted: 21:08 - 09 Aug 2008    Post subject: Reply with quote
Dunlop and Death start with the same letter! Get rid of them.
Also, why do you think you never see Dunlop stickers on motorbikes. Its because they don't stick! They have all fallen off. Dunlop don't make sticky things! Laughing
Do you ride rain or shine, Or are you that fair weather rider?
If you are a dry / sunny only rider, then go for the Pirelli Supercorsa's.
https://www.motomanija.com/fotoz/Gume/2006/julij/Pirelli_DiabloSuper/title_s.jpg
If you ride in the wet then I cant help because I see no enjoyment of taking a bike out on a rainy day. Id rather take the car.
Ben
Fastkwak
PostPosted: 23:56 - 09 Aug 2008    Post subject: Reply with quote
Ben
Ha Ha top post mate im with you on that one karma coming your way Thumbs Up Mr. Green Thumbs Up
CB125T superdream
Deckx
PostPosted: 05:23 - 10 Aug 2008    Post subject: Reply with quote
where did you find the set-up guide ?
Scouse
PostPosted: 18:21 - 10 Aug 2008    Post subject: Reply with quote
Looks like the one out of performance bikes mag.
Coxyzxr
PostPosted: 18:31 - 10 Aug 2008    Post subject: Reply with quote
Double check those pressures and take cold readings not after riding to the garage to do it Laughing
I had the feeling of the back end nibbling out quite a bit, turns out tyre pressure was below what should of been and it makes the tyre wall flex, basicly simulates sliding out.
**WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID !
The last post was made 18 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.14 - MySQL Queries: 13 - Page Size: 116.43 Kb
