optimax with a 2 stroke engine
sc125
PostPosted: 22:07 - 08 Aug 2008    Post subject: optimax with a 2 stroke engine Reply with quote
hi guys just wanna know if i can run my 2 stroke bike on optimax, and some octane booster every now and again. thanks
PostPosted: 22:32 - 08 Aug 2008    Post subject: Reply with quote
If you'd had enough tuning work done to need an octane booster, you'd already know if you needed it or not. So don't add octane booster, you don't need it.
Optimax is pretty good in small 2-strokes as it happens.
Makes my H100 use significantly less fuel. Enough so it makes up for the difference in price between the optimax and standard unleaded.
sc125
PostPosted: 22:37 - 08 Aug 2008    Post subject: Reply with quote
ive had the dealer, and another guy tell me not to use optimax, saying that it would make the engine run hotter as its only a single piston??, im fairly mechanically minded and dont see how it would run hotter, i thought the higher the ron the more effiicent and cleaner the 'burn' is?.
yandy_yay
PostPosted: 23:04 - 08 Aug 2008    Post subject: Reply with quote
Erm cleaner and efficient, does that not equate to a longer burn ? hence the increase in temp. if it does burn hotter can you not get a different temp sparkplug ?
Just babbling as i don't really know anything.
past bikes: (20 years ago) cg-125 (wriiten off), C-50 (thrashed n' finnaly scrapped), CZ-125 (nicked - never recovered, insurance payout was more than i paid for it !!!)
Current bikes: GN 125(now sold), Divvy 600s.
sc125
PostPosted: 23:10 - 08 Aug 2008    Post subject: Reply with quote
dont think so, its more efficent because it burns all of the fuel sucked into the cylinder and reduces detting, which is a good thing, plus i might be after a new exhaust and as its only a 125 with the optimax exhaust and getting it set up properly on a dyno might see a slight increase in power.
cal91
PostPosted: 00:07 - 09 Aug 2008    Post subject: Reply with quote
i run my 2 stroke on the tesco stuff which is very similar. I only run it cos it has cleaning stuff in the petrol. I cant really feel a difference in speed.
Its tick over is higher and it runs alot better on it. It starts better as well.
But it doesnt run any hotter, well i dont think so. My oil and temp light come on after 10 mins of riding anyway. Its a fault lol but i dont really care tbh. They flicker with my idicators as well (get brighter when the indicators are flashing, when the bulbs are on not off).
We are the Patriots! Love your country.
PostPosted: 05:56 - 09 Aug 2008    Post subject: Reply with quote
Bad earth.
PostPosted: 06:55 - 09 Aug 2008    Post subject: Reply with quote
Higher octane means a slighly slower flame-front which has the effect of (extremely) slightly retarded ignition. You don't NEED optimax in any standard bike engine but using it won't do any harm.
PBCup
PostPosted: 06:58 - 09 Aug 2008    Post subject: Reply with quote
Can't see VPower running hotter.
As far as i'm aware the higher the RON the slower the burn so I would guess that meant cooler too.
I run my RS125 exclusively on shell VPower, end of the day the compression ratio is high so IMO that means you need higher ron to stop pinking etc.
PostPosted: 08:20 - 09 Aug 2008    Post subject: Reply with quote
Without saying it's the case here, a retarded ignition does produce more heat in the cylinder.
tony_d123
PostPosted: 09:11 - 09 Aug 2008    Post subject: Reply with quote
Just wasting your money.
PostPosted: 21:57 - 10 Aug 2008    Post subject: Reply with quote
Can't see the relevance of it being a single.
Nope. Higher RON just means it is more resistant to detonation. Does not mean that it will be more efficient or a cleaner burn.
MinhDinh
PostPosted: 22:11 - 10 Aug 2008    Post subject: Reply with quote
i find ultimate a lil faster than standard petrol from murko or whatever it is. at first i didn't notice but with experience i do. it seems like with the standard petrol my bike feels sluggish like it is low on petrol while ultimate seems to either last longer or is generally better. then again i don't have any proof. maybe it is my imagination.
Hit the G spot. Wink
The last post was made 18 years, 97 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.06 - MySQL Queries: 13 - Page Size: 78.78 Kb
