125 won't start
gevans
PostPosted: 16:48 - 09 Aug 2008    Post subject: 125 won't start Reply with quote
i have a Vulcan Custom 125 (obscuro chinese bike) that has decided it won't start. this seems to be the same problem as in
https://www.bikechatforums.com/viewtopic.php?t=131745&highlight=vulcan
it worked fine on thursday, was parked in the garage, and wouldn't start on friday.
I have no spark when checked (used a spare spark plug) and there is fuel getting through the system.
any idea what i need to be looking at (replacing/fixing)? - the other thread seemed to just stop without a fix managed...
ST125SM
PostPosted: 16:53 - 09 Aug 2008    Post subject: Re: 125 won't start Reply with quote
gevans wrote:
I have no spark
That'll be the problem then Laughing
As long as you're sure the spark plug is good, you should next test the HT cap.
Regards,
Mike
Frost
PostPosted: 17:45 - 09 Aug 2008    Post subject: Reply with quote
make sure that the body of the plug is touching the engine or it wont spark. Also try checking at night as this will better allow you to see a spark. Darkness will also allow you to see if the spark is shorting and jumping from the HT lead to somewhere else. If you have no spark at all then that is the problem. Check allt he wiring and the fuses to see if they are the problem. If not buy a new coil (not much) and try that.
The last post was made 18 years, 84 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 35.3 Kb
