Any electricians?
rhone81
PostPosted: 19:47 - 10 Aug 2008    Post subject: Any electricians? Reply with quote
The lights in my girlfriend's flat have gone after we (I Embarassed ) replaced her strip light with a normal one. Instead of one wire with L,N & E coming out of the ceiling there were 3 with L,N & E bundled together respectively. Got the new light wired up but all lights are now not working.
Took the fuse out to change it but never seen one like it before. It is a 5 amp Memera branded fuse and has a black plastic face and two pins at back which plug into box. Between the pins instead of something I would recognise as a fuse there is a hollow block.
Anyone know what type it is and/or where I can get one?
Cheers,
Graeme
tutton
PostPosted: 19:59 - 10 Aug 2008    Post subject: Reply with quote
Sparks!
is a sparkie.
Might be worth a pm, dosnt mean hes going to help tho Laughing
Finglonga
PostPosted: 20:05 - 10 Aug 2008    Post subject: Re: Any electricians? Reply with quote
How old is the consumer unit?
Is the fuse made of Bakelite?
If so the fuse may be the old type that have replaceable fuse wire. A picture would help.
Andy Sez....
F.Y.Y.F.F.
Ariel Badger
PostPosted: 20:10 - 10 Aug 2008    Post subject: Reply with quote
Does your girlfriend know what to do in the case of your electricution?
rhone81
PostPosted: 20:18 - 10 Aug 2008    Post subject: Reply with quote
It's the one on the right: picture link
I need a shop that sells 5 amp version of this so I can replace it tomorrow. Raking Google just now...
Bury me in the Green, sell the bike and give you a phone...? Very Happy
S1KE
PostPosted: 20:24 - 10 Aug 2008    Post subject: Reply with quote
you have wired it wrong, the three wires coming out of the ceiling with l,n,e are not what they seem, some of the black wires should have red sleeving over them making them switch lives, you need a electric screw driver and to disconnect your new light and switch the power on and figure out which wires are what!
random twat!
* xbox live mickeyc26
* zx6r b1h 2004 GREEN !
rhone81
PostPosted: 20:35 - 10 Aug 2008    Post subject: Reply with quote
None of the ceiling lights in the flat are working so I've done a right job of it! Why are there 3 sets of wires? I'm a bit lost here.
S1KE
PostPosted: 20:42 - 10 Aug 2008    Post subject: Reply with quote
well you prob have two switches for that light right? one comes from each switch and the other should be the main wire which prob goes to the next light, im not 100% sure as im a plumber! but deal with some basic part p electrics, but im 100% that you have your lives and switch llives mixed up, and without actually seeing the light i cant tell you where to put thewires Thumbs Up
random twat!
rhone81
PostPosted: 20:56 - 10 Aug 2008    Post subject: Reply with quote
Just the one switch for that light. Would process of elimination work by trying each in turn? What would happen with the 2 groups of wires left over?
Sparks!
Sir Tart-a-lot
PostPosted: 21:10 - 10 Aug 2008    Post subject: Reply with quote
Bwahahahah I love home-electricans who have no clue Laughing
Your house wiring is 3 plated which means you have a Loop, Neutral and Switched Live... TBH I don't think I trust you to get it right so I'd say call in someone who knows what they are doing...
If you've taken the markings off the cables and don't know what is what then really you should turn the power off and bell the cables out with a continuity tester.... turning the circuit on and seeing what's live will find one of the cables but that's all and you'd prob electrocute yourself anyways Laughing I wouldn't reccomend doing it by trial-and-error... you could still get it wrong and the light function correctly if you accidentally switch the neutral.... which altho it'd work, you don't want it happening..
Just get someone in who knows what they are doing Thumbs Up
yandy_yay
PostPosted: 21:18 - 10 Aug 2008    Post subject: Reply with quote
Righto here we go. you should have 3 sets of twin and earth probably the old colours red/black but if its new wiring it'll be blue/brown...i digress....
from the consumer unit (fuse box) you'll have a twin and earth going to light fitting 1, then from there another twin and earth going to light fitting 2, then from there another twin and earth going to light fitting 3 and so on finally from the last fitting on that circuit a twin and earth back to the consumer unit.
Now from each light fitting there should be a 3rd twin and earth (it should be twin reds, but not always so as mentioned in the thread already there might be red tape around some black(or blue) wire, but again some shoddy workmen don't do that either)
so what we need to do is TURN OFF THE POWER first, then disconnect the new light an untangle all the wires so that the bare ends are not touching any other bare ends.
you need a tester of some sort either the old neon type or a multimeter that goes to atleast 250Vac.
repair replace the fuse and turn the electricty back on.
now with ur tester you should find only 2 of the red(or brown) wires are live (there i a possiblitly that only 1 will be live but i have only ever seen an incomplete circuit once) anyhows hopefully yu should have 2 lives, these pair of twin and earths form the loop you should now TURN OFF the power again and using suitable connectors join the red to red(or browns) and the black to black(or blues) you also need to take the nuetral from you new fitting to the black wires(or blue) and 1 of the remaining wires in the 3rd twin and earth to the reds(or brown) and finnally the other wire in the 3rd twin and earth to the live on your new fitting, join all the earths together and also earth your new fitting (if it has an earth point)
my mspaint skills are not good.
HTH
past bikes: (20 years ago) cg-125 (wriiten off), C-50 (thrashed n' finnaly scrapped), CZ-125 (nicked - never recovered, insurance payout was more than i paid for it !!!)
Current bikes: GN 125(now sold), Divvy 600s.
Sparks!
Sir Tart-a-lot
PostPosted: 22:16 - 10 Aug 2008    Post subject: Reply with quote
Yandy, there is a feed in and a feed out on the loop so only the feed in will be live if all the cables are seperated ....so only 1 cable will be live you'd still need to work out what is feed out and what is the switch live.
If both ends are live then you'd have issues as lighting circuits are RADIAL which means they go
Fuseboard ---> Light 1 ---> Light 2 ---> Light 3
NOT
Fuseboard --> Light 1--> Light 2 --> Light 3 --> Fuseboard
The above would mean 2 cables would be live at a fully disconnected light point.... and that is wrong!
So basically what I'm saying is if you disconnect all the cables at light 1 then light 1 would have a single live cable and light 2 and 3 will have no supply at all.
yandy_yay
PostPosted: 22:19 - 10 Aug 2008    Post subject: Reply with quote
erm.. it should be a complete loop back to the consumer unit so the loop gets fed from both ends.
Sparks!
Sir Tart-a-lot
PostPosted: 22:21 - 10 Aug 2008    Post subject: Reply with quote
No mate, you are tihnking of a ring final for sockets Rolling Eyes Lights are RADIAL. they do not return to the fuseboard.
yandy_yay
PostPosted: 22:26 - 10 Aug 2008    Post subject: Reply with quote
i stand corrected. Sorry.
in that case with the power off we could do a continuaty test from the switch to the ceiling to find which of the remaining 2 twin and earths is the one to the switch, leaving the other one that goes off to the next light fitting.
Sparks!
Sir Tart-a-lot
PostPosted: 22:43 - 10 Aug 2008    Post subject: Reply with quote
That's more like it Smile
carvell
Scuttler
PostPosted: 22:44 - 10 Aug 2008    Post subject: Reply with quote
I thought I'd have a go in paint too, but with labelling the connector blocks found in a ceiling rose!
OP - if you've simply connected all the L, N and E coloured wires together then as soon as you turn on the switch you'll blow the fuse again, as people have said you have to work out what's what!
https://www.bikechatforums.com/download.php?id=59566
Yamaha TDM 850
Sparks!
Sir Tart-a-lot
PostPosted: 22:50 - 10 Aug 2008    Post subject: Reply with quote
Do people not know that if you hold CNTRL key whilst drawing in paint it makes the lines straight Laughing
10/10 for effort tho Laughing
carvell
Scuttler
PostPosted: 22:53 - 10 Aug 2008    Post subject: Reply with quote
I've never seen a straight wire in a ceiling rose. I was going for realism. Wink
and no, I didn't know that
Yamaha TDM 850
yandy_yay
PostPosted: 23:00 - 10 Aug 2008    Post subject: Reply with quote
LOL Thumbs Up
Sparks!
Sir Tart-a-lot
PostPosted: 06:20 - 11 Aug 2008    Post subject: Reply with quote
Laughing Laughing
PostPosted: 07:55 - 11 Aug 2008    Post subject: Reply with quote
You mean shift key Wink
Cigaro
PostPosted: 11:42 - 11 Aug 2008    Post subject: Reply with quote
It's what they call a 'ring'.
Basically, one cable comes from the previous light fitting, one cable goes to the next. The red and black of those should be connected together within the fitting.
The third cable goes from the red wire of the input side, to a light switch, and then back to the actual light itself. The black wire on that cable is the 'switched live' that people have talked about. The other side of the light then connects to the neutral (black wire of the ring).
The earths should be tied together.
If you don't understand this, I suggest you call an electrician.
yandy_yay
PostPosted: 14:51 - 11 Aug 2008    Post subject: Reply with quote
I wondered why it didn't work Twisted Evil
Sparks!
Sir Tart-a-lot
PostPosted: 16:17 - 11 Aug 2008    Post subject: Reply with quote
It is not called a ring!
Seriously people, don't give advice if you don't know what you're talking about.
The last post was made 17 years, 324 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.73 - MySQL Queries: 13 - Page Size: 134.59 Kb
