Electrical issue
c_dug
PostPosted: 08:54 - 11 Aug 2008    Post subject: Electrical issue Reply with quote
Ive got a bit of a confusing problem with my electrics,
When my headlight is on the indicators work perfecty, as soon as i switch the headlight off the indicators come on but dont flash. Confused
Any ideas? Its not really that big a problem since my headlight is always on but its one of those things that i need to get sorted some time so i might aswell do it.
c_dug
PostPosted: 09:09 - 11 Aug 2008    Post subject: Reply with quote
It's probably a bad frame earth connection.
Odd flasher faults usually are, they'll be earthing via the tail light when it's on and earthing not very well via a frame earth when it's not. You may even find the tail light/brake light filament glowing a bit when you turn the flashers on if you look at it in the dark
Check for a frame earth somewhere under the saddle in the vicinity of the rear mudguard/subframe. Corrosion on this, while not the only suspect, is your most likely culprit.
c_dug
PostPosted: 09:39 - 11 Aug 2008    Post subject: Reply with quote
cheers ill go have a look now Thumbs Up
c_dug
The last post was made 18 years, 96 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 36.3 Kb
