peugeot streetfighter 50cc running probles!
penny1664
PostPosted: 15:18 - 11 Aug 2008    Post subject: peugeot streetfighter 50cc running probles! Reply with quote
i have the above ped, it has been running ok then i started getting a few problems with it, it will start and idle but when i use the throttle it revvs for a bit then starts to lose power like it is not getting enough fuel, it loses power until it stalls, i have checked and cleaned the carb, checked the fuel flow, drained and cleaned the fuel tank, also i put a new spark plug in. any help would be great, ta
depechedave
PostPosted: 19:31 - 11 Aug 2008    Post subject: Reply with quote
when you kick it up whack open the throttle until the smoke clears then leave it running for a bit ,this worked for me but only after i had adjusted the fuel flow as i screwed the carb the wrong way ,turn it so the spring gets tighter but keep kicking the bike until the engine kicks up and then rev the nuts of it until the smoke clears, this worked for me but it took a little time as you only need to make minor adjustments to the screw. hope this helps
prawny1
PostPosted: 22:08 - 11 Aug 2008    Post subject: Reply with quote
Peugeot scoots tend to do that sort of thing when the immobiliser has packed up, does your led stay on when the scoot is running?
There is a flash code that the led displays when the immobiliser is faulty but i can't off the top of my head remember what it is.
The last post was made 17 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 34.92 Kb
