When riding over bumps or changes of road surface...
Cigaro
PostPosted: 10:02 - 12 Aug 2008    Post subject: When riding over bumps or changes of road surface... Reply with quote
it feels like my back tyre is slipping around.
I never experienced this on any of my previous bikes.
Is it just because this bike has a much larger back tyre than anything I've ridden before? The tyre looks in good condition.
I can tell that the bike's going to stay upright, it just feels slightly unnerving, like I'm losing the back end.
Feasty
PostPosted: 10:12 - 12 Aug 2008    Post subject: Reply with quote
Similar thing here, I'm finding every bump I go over literally makes me jump out of my seat! Accelerating up a bendy slip road the other day made the back end feel kind of skitish. I'm guessing the tyre pressure is too high (I've yet to find any manuals about my bike pressures!) or the suspension is too hard - no idea how to change that though, if indeed I can!
Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed). Also now a Tiger 1050, easily best of the lot!
truslack
PostPosted: 10:17 - 12 Aug 2008    Post subject: Reply with quote
What pressure are you running it at?
Cigaro
PostPosted: 10:32 - 12 Aug 2008    Post subject: Reply with quote
I've not actually checked it yet Embarassed Do you think it's too high?
iooi
PostPosted: 13:36 - 12 Aug 2008    Post subject: Reply with quote
Rather than look in the handbook for tyre pressures. Visit the tyre manufactures site and look for you tyre.
Seems many replacement tyres run better at pressures diffrent to OEM stuff.
colin1
Captain Safety
PostPosted: 15:21 - 12 Aug 2008    Post subject: Reply with quote
tyre manufacturers will just give max pressure which will be a lot higher than the pressure specified in the manual for your bike
tyre manufacturers do not give recommended running pressures, they just give max pressures which are not designed to be actually used
you need to run it at the pressure stated in your bike handbook or manual
truslack
PostPosted: 15:28 - 12 Aug 2008    Post subject: Reply with quote
The pressures are conditional, and one of the factors would be the type of tyre, different makes/types WILL run better at different pressures.
Feasty
PostPosted: 15:32 - 12 Aug 2008    Post subject: Reply with quote
I don't have a manual for my SLR650 and so have no idea what the tyre pressures are supposed to be, I've just put them to the same as my XR was with a little extra for the added weight! But still plenty lower than the max stated on the tyre wall...
Cigaro
PostPosted: 15:58 - 12 Aug 2008    Post subject: Reply with quote
Thing is, I don't have a handbook - does anyone happen to know the correct tyre pressures for a Kawasaki EL250?
Cheers.
deanoet
PostPosted: 16:23 - 12 Aug 2008    Post subject: Reply with quote
is it printed on the swing arm?
They are on mine, not sure if that is a standard across the manufacturers though..
St0rmer66
PostPosted: 16:32 - 12 Aug 2008    Post subject: Reply with quote
Think on the XR125 is was 23psi back and front if I remember correctly. Though I'm not sure if you meant you just don't know it for the SLR650.
:: Honda XR 125 L ('53) => Kawasaki GPZ 500S ('02) => Suzuki SV650S ('00) => Aprilia RSV-R ('51) ::
colin1
Captain Safety
PostPosted: 19:25 - 12 Aug 2008    Post subject: Reply with quote
it will be something between 20 psi and 40 psi, most likely very close to 30psi
so if you put the kind of pressure in thats stated on the tyre wall 60psi or so, that would be wrong
the pressure tyre manufacturers put are not actual pressures you are meant to run at, just pressures that the tyre can withstand, when it heats up etc
yambabe
PostPosted: 21:46 - 12 Aug 2008    Post subject: Reply with quote
You're not fat enough! Laughing
No idea what the correct pressure is but I always kept the back hard cos of my somewhat porky weight on what is after all only a fairly small bike. Embarassed
Never had a problem with slippage with that tyre though Confused except occasionally when it was very wet. You may find it settles down of its own accord when the weather gets better.........
Ichy
PostPosted: 22:36 - 12 Aug 2008    Post subject: Reply with quote
New tyres or a new bike will always feel a little weird due to changes in the tyre shape. REALLY noticeable when cornering.
Cigaro
PostPosted: 08:40 - 13 Aug 2008    Post subject: Reply with quote
Well, I took a bit of air out of the back tyre last night, and it seems a little better now.
Think it's just wet roads and dodgy surfaces that are the problem, it mostly happens (happened) when going over repairs in the road where it had been filled in with that black tarmacy stuff.
Anyway, it's all good now Thumbs Up
The last post was made 18 years, 80 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 83.27 Kb
