Power Fuel Racing Chip?
Demonic69
The Pink Rhino
PostPosted: 13:37 - 17 Aug 2008    Post subject: Power Fuel Racing Chip? Reply with quote
Anyone tried one of these? I'm ideally after improving the fuel economy, not gaining power, on the ZX-12R.
Seems OK for the money, just not convinced.
Back on a Blade. Just feels so right.
Itchy
PostPosted: 13:39 - 17 Aug 2008    Post subject: Reply with quote
Is this one of those dodgy chips you find on ebay which just tricks the ECU into thinking conditions are different to what they really are, and thus the engine runs lean and hot (possibly burning holes in yer pistons?) or something else?.
Demonic69
The Pink Rhino
PostPosted: 13:43 - 17 Aug 2008    Post subject: Reply with quote
Good question.... no idea Very Happy
Comes across as something similar to a Power Commander, but who knows?
Egret
PostPosted: 19:22 - 18 Aug 2008    Post subject: Reply with quote
they did something on chipping a diesel golf for fuel economy on fifth gear. I know the vehicle is different, but I believe it's pretty much the same thing, custom maps for the ecu to make the thing run leaner. It made no difference on the golf, actually being slightly detrimental. My guess is that any gains would depend upon the quality of factory settings in the ecu.
PostPosted: 19:27 - 18 Aug 2008    Post subject: Reply with quote
The cheapo things on Ebay are probably just resistors to go into the wiring loom to the temperature sensors and trick the ECU into adjusting the mixture. Total bodge job.
To be honest, worth getting it done properly. And there are other alternatives to a power commander.
Demonic69
The Pink Rhino
PostPosted: 20:55 - 18 Aug 2008    Post subject: Reply with quote
Ah Mr Oracle. Anything you can recommend?
PostPosted: 21:04 - 18 Aug 2008    Post subject: Reply with quote
Hi Dean
Take it to a decent dyno centre. Power Commander is just one of the things used to fiddle around with the inputs. Other companies make equivalents (just Power Commanders are by far the most well known).
Possibly having a word with John Warrington in Malton (east of York) who should be pretty close to you and knows what he is doing.
Cigaro
PostPosted: 06:08 - 19 Aug 2008    Post subject: Reply with quote
I thought what these things actually did was make the ECU think it's slightly colder, thereby causing it to run slightly richer, not leaner?
PostPosted: 06:37 - 19 Aug 2008    Post subject: Reply with quote
But if it ran richer it would use more fuel.
Demonic69
The Pink Rhino
PostPosted: 06:50 - 19 Aug 2008    Post subject: Reply with quote
Well according to their spiel it advances the ignition timing and has 15 different maps for the fuelling.
Thought that might be a pretty tall order.
PostPosted: 07:39 - 19 Aug 2008    Post subject: Reply with quote
Probably tries to adjust the timing by fiddling the the gear position sensor or possibly the inlet air temperate.
Cigaro
PostPosted: 09:51 - 19 Aug 2008    Post subject: Reply with quote
Yep, they do.
By the way, I'm referring to the £5 'chips' on ebay which aren't actually chips at all, they're just little resistors.
But this probably does a similar thing. It looks too cheap to be a proper tuning system, which normally take the form of a piggyback ECU.
Demonic69
The Pink Rhino
PostPosted: 10:24 - 19 Aug 2008    Post subject: Reply with quote
They're £40 and apparently connect into the ECU
Cigaro
PostPosted: 10:38 - 19 Aug 2008    Post subject: Reply with quote
I bet my right teste that it's not a proper tuning device though.
It may work, but not very well.
The last post was made 17 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 82.42 Kb
