| D O G |
 D O G World Chat Champion
| Jamie S |
 Jamie S World Chat Champion
 ---- World Chat Champion
 Posted: 22:59 - 17 Aug 2008 Post subject: |
Not sure if you can,but it seems like false economy though innit?
If your going to strip it all down and probably have to change gaskets would it not make more sense to fit new clutch plates while your on? ____________________ DRZ-400sm |
| D O G |
| Itchy |
 Itchy Super Spammer
 Posted: 11:12 - 18 Aug 2008 Post subject: |
He is an accountant type ..... eventually they all become like that...
I'm fighting an epic battle not to become like that , and I'm apparently losing.... ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| chris-red |
| LanaTheGreat |
 LanaTheGreat Scooby Slapper
| cestrian |
 cestrian World Chat Champion
| D O G |
| Kickstart |
 Kickstart The Oracle
 Posted: 07:35 - 19 Aug 2008 Post subject: |
There is an adjuster on the sprocket cover. Slacken the adjuster off at the lever and pull off the rubber cap over the sprocket cover adjuster. From memory you need a 10mm or 12mm box spanner and a screw driver. Slacken off the lock nut with the box spanner, slacken off the screw with the screw driver, then tighten the screw until it just makes contact and then back it off again slightly. Holding the screw steady then tighten up the lock nut.
Oil can have odd effects, but I have used car oil in my FZR without problems (that is what is in there now). I did have a similar problem to you when I first bought it and that was caused by worn plates.
| cestrian |
The last post was made 17 years, 139 days ago. Instead of replying here, would creating a new thread be more useful? |
