New brake pads won't fit
Scotch Bonnet
PostPosted: 08:26 - 19 Aug 2008    Post subject: New brake pads won't fit Reply with quote
So, being an inattentive eejit and that, I managed the let my back brake pads wear down to bare metal, though thankfully picked it up before i totally screwed the disc.
Bought some cheapy £10 pads from wemoto, and cannot for the life of me fit both of them in, there's maybe a full 1mm more friction material than can fit in there with the disc in.
I've made sure the piston's fully retracted, got the top off the master cylinder and carefully stuck a flat wedge in between the caliper and the disc
Is it likely I've missed something obvious that would stop them going in? Alternatively, is there a safe way to wear them down a bit so they do fit? I did think of running just one of the new ones for a couple of hundred miles until it was a bit more worn, but with the old pads being beyond hope it's not really an option.
Hmmmm..... is it supposed to do that?
2001 CB500
MaybeGuy
PostPosted: 08:30 - 19 Aug 2008    Post subject: Reply with quote
if all else fails you could file it down a bit?
PostPosted: 08:45 - 19 Aug 2008    Post subject: Reply with quote
And get aspesdos (Sp) in you lungs Thumbs Up
MaybeGuy
PostPosted: 08:49 - 19 Aug 2008    Post subject: Reply with quote
i thought they stopped making asbestos brake pads decades ago...
tzr
PostPosted: 08:51 - 19 Aug 2008    Post subject: Reply with quote
If it's the same caliper (mine is) then you could use one partially worn off the front?
veeeffarr
PostPosted: 09:00 - 19 Aug 2008    Post subject: Reply with quote
You sure you got the pistons pushed all the way in? Put the old ones in and twist a flat bladed screwdriver in between them to lever them back into the caliper.
Make sure the M/Cyl is open and the surround area is covered, be prepared to have to remove some fluid.
T
carvell
Scuttler
PostPosted: 09:01 - 19 Aug 2008    Post subject: Reply with quote
You probably haven't wound the pistons all the way in. Use a g clamp if necessary.
Yamaha TDM 850
Finglonga
PostPosted: 09:46 - 19 Aug 2008    Post subject: Reply with quote
They did so just file them down. Wink
Used to do that when there was the asbestos in them anyway.
Andy Sez....
F.Y.Y.F.F.
Itchy
PostPosted: 10:22 - 19 Aug 2008    Post subject: Reply with quote
WAAIT..
clean the pistons up BEFORE you push them in , otherwise you'll be asking on here my brakes are seized which is a strip and rip job, not so bad on a two pot single caliper machine but on a opposed piston machine you need a special tool (to make life much easier).
The last post was made 17 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 62.82 Kb
