Indicators
DaveS
PostPosted: 21:58 - 25 Mar 2004    Post subject: Indicators Reply with quote
I have just been out on my F-Reg Yamaha TZR for the first time but there are a couple of problems can anybody help?
a) the battery must be bad because the lights dim when i press brake etc.. where is it and how much would a new one cost?
b) while the front indicators don't work at all the rear ones stay lit when 'on' instead of flashing. Could the problem be something to do with the fact that the fronts don't work and how can I check why they don't?
Or could it be the relay? Where is this?
Many thanks in advance
..Dave
MitoIslander
PostPosted: 01:00 - 26 Mar 2004    Post subject: Reply with quote
Not sure about the TZR, but I know my Mito keeps the indicators on when you remove one, EG. If the front left isn't working / connected, the rear left stays on.
This is when they work at all.
Check the bulbs, wiring ETC.
Jay
ZaphodBeeble
PostPosted: 03:49 - 26 Mar 2004    Post subject: Reply with quote
If there isn't enough voltage supplied to the indicator relay it will stay either on or off. As you say you have battery problems then I would replace or charge the battery and see if all the electrics are functioning OK before stripping anything down. Thumbs Up Wink
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
DaveS
PostPosted: 20:02 - 26 Mar 2004    Post subject: Reply with quote
Seems not to work with a new battery so going to have to do some wiring maybe..
Time for a post in Workshop Confused
NSR125-Kid-UK
Attention Whore
PostPosted: 00:51 - 27 Mar 2004    Post subject: Reply with quote
I tried to "tuck some wires away" (hide them between the fairing panels) on my NSR and inadvertently unplugged my front right indicator. When the right indicators are switched on, the rear left indy and indicator warning light stayed on without flashing, until i plugged the indicator back in. It's most likely a loose connection mate.
On my NSR the lights dim slightly when i use either brake, and it's the same on my work scooter (which is less than 5 months old) so it's probably not a problem.
Best of luck sorting it out mate Thumbs Up .
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
Slinn84
PostPosted: 21:37 - 21 Apr 2004    Post subject: Reply with quote
both indicators run in a circut, the rear left flashes once, then cuts off to let the front left one flash, if one doesn't work or is disconnected then the other one will stay on constantly.
The last post was made 21 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 48.04 Kb
