SR125 Won't rev above about 2000rpm
Bike Chat Forums Index -> The Workshop via View All Topics
craptiger
PostPosted: 13:02 - 19 Aug 2008    Post subject: SR125 Won't rev above about 2000rpm Reply with quote
Hi,
My girlfriends SR125 has suddenly developed a problem where it won't rev above about 2000rpm. If you open the throttle the engine actually dies. We've tried with choke in, out, halfway. It'll idle with the choke partly out, but as soon as you increase the revs it dies. We've left it to warm up, then tried again, to no avail.
Any ideas?
Thanks
chillpill
PostPosted: 13:15 - 19 Aug 2008    Post subject: Reply with quote
clean you carb-o-rama , whack in a new plug, give the air filter a wash then hey presto Razz
alex Cool
L3G3ND_MTX
PostPosted: 13:16 - 19 Aug 2008    Post subject: Reply with quote
Tried looking at the carb/Plug? could be flooding itself when your revving which means too much petrol getting in which is genrally something to do with the carb or just check the plug to see if its burning fuel properly and not flooding?
Just some ideas, im sure someone will come and correct me.
Also how do you know what its revving to? i thaught sr 125's were scooters? unless im mistaken and thats only the sr 50's Confused
PostPosted: 13:24 - 19 Aug 2008    Post subject: Reply with quote
Yamaha SR125. Not sure if they have rev counters but that's probably why he said 'about 2000rpm' because he doesn't know for sure.
craptiger
PostPosted: 13:26 - 19 Aug 2008    Post subject: Reply with quote
Hi,
Thanks for the tips. I don't know exactly what it's revving to at all, 2000 was a rough guess based on my experience of bikes as a whole!! Basically it won't rev anywhere near half way, and not a great deal above idle speed.
The weird thing is how it's suddenly happened, but I'll clean the air filter, change the plug and try it again. Might drain the fuel out and change that too - would water in the fuel cause these symptoms? Or possibly a piece of grit? Surely that would cause it to not run at all though?
My 1950 land rover once actually had a problem where a vacuum was being created in the fuel line so once it sucked a certain amount of fuel in it stalled - anyone know if there's a breather on the fuel tank on an SR125?
p.s. I'm fairly certain it's not flooding because I've tried increasing the revs really really slowly and it still cuts out at about the same point
Cigaro
PostPosted: 13:27 - 19 Aug 2008    Post subject: Reply with quote
Blocked air filter?
prawny1
PostPosted: 13:40 - 19 Aug 2008    Post subject: Reply with quote
The cdi may not be advancing or not sparking at higher rpm, Iknow they are usless for on the road but i have found that light up sparkplug caps help to eliminate the not sparking at higher revs question as you will see the sparking stop or not as the case may be.
yen_powell
PostPosted: 15:16 - 19 Aug 2008    Post subject: Reply with quote
Most likely a bit of dirt has blocked one of your jets in the carb, maybe the multi holed emulsion tube. This means the bike will start and tickover, but try and die when you rev it.
Give the carb a strip and clean (don't change any settings) and fit a fuel filter to stop it happening again.
Had the same on an SR125 I looked after for a friend.
XT1200Z and a DR350 in bits
FerretFing
PostPosted: 17:10 - 19 Aug 2008    Post subject: Reply with quote
the air filter on the SR is very sensitive to being "over oiled" - use something thinner like wd40 as opposed to engine oil & make sure it`s well squeezed (gently!). Check condition of plug for clues Thumbs Up
craptiger
PostPosted: 06:47 - 20 Aug 2008    Post subject: Reply with quote
Well I found the problem!!
I took the air filter out and having no handy containers of petrol, ran it for a second without it and it still ran badly. So I changed the plug, to no avail.
I then took the carb off, dismantled it and put it back together again after a clean and hey presto - she ran like a beaut.
It might have had something to do with the large piece of gravel that fell out when I opened it up!!
Thanks for all the help everyone.
1997 Honda VFR750 (for fast fun) : 1995 Suzuki GS500 (boring commuting) : 1950 Land Rover (muddy fun) : 10.5 metre kite (scary aerial fun)
The last post was made 17 years, 192 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Workshop via View All Topics All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 63.13 Kb
